QuickStart 3.3V as a power source?
If it is USB powered, or anyway powered with a source before the voltage regulator,
can I use the Quickstart 3.3V pin to power something (in my case a XBee 50mA module that it 3.3V too)?
If so, what Amps max (because maybe it is passing through the PCB, and the power regulator limit which I don't know, etc.)?
Marc
Marc
And then the QuickStart has a Propeller that has a maximum power limit (to avoid stress) of 300ma.
There is also the USB to serial chip that requires power (from the 5 volts) and provides the Propeller with +3.3v. And don't forget the EEPROM. So there is NOT much headroom.
Take a look at the specs for the FTDI 232RL, which is the USB to Serial chip. It provides the 3.3v output.
Try page 17, but I can't seem to find a figure.
Try top of page 11, and it seems that the FTDI 232RL provides 50ma of 3.3v Total, for the Propeller, the EEPROM, and whatever you might want to add.
(Wow, that is low!)
http://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT232R.pdf
From the user guide:
/USB_PWR_EN USB power enable pin, inverted. Pulled to USB 5 V supply. Internally pulled
low after successful USB power negotiation. Drive low to force the USB power input to drive the
QuickStart power supply. Drive high with 6 VDC to disable power sourcing from the USB
connector. Rev B and later boards also internally pull low /USB_PWR_EN low upon detecting a
USB charger. Rev A boards must have /USB_PWR_EN externally driven low to power from a USB
charger.
But if you use Vin at +5v, it seems that the AP1117-3.3 would be able to deliver up to 1 amp distributed to the parts in place, and whatever is added.
The FTDI chip apparently will be happy just as long as it is getting somewhere between 5 and 3.3 volt DC.
That drive High to 6VDC is a bit disconcerting. Not sure about the Vin being safe for over 5 VDC. I guess the FTDI chip is being powered with 3.3V downstream from the regulator, so all is safe. I still don't under how the 3V3OUT pin wiring in the schmatic.
I need to read more about the QuickStart. I just have never bought one or used one. I still have quite a few ProtoBoards.
That Mosfet Q2 is there to shut out the +5VDC from the USB port. Is that correct.
So, with power from a USB port, you migh have only 500ma total at best, but with another Vin source you can get up to 1 amp total.
Total means that you have to include the Propeller, the EEProm the FTDI chip, and the on-board LEDs in your power consumption budget.
Since how you use the Propeller varies and might go as high at 300 ma, my 'best guess' is that you easily have 100ma available for external device power from the 3.3v powered only by the USB ports +5, and it could be much more.
