Playing audio backwards?
Has anyone tried playing an audio file backwards, with a propeller?
I'd like to build a science museum exhibit which duplicates a process I used to do with tape:
Record a spoken phrase
Flip the tape around and play the phrase backwards
Learn (as best you can) to speak the backwards sounds
Record the backwards speech
Flip the tape again and play it
Hilarity ensues, as I remember (there may have been herbs involved - it WAS 1972)!
In general, it could be a problem playing an SD FAT file backwards because FAT filesystems don't provide a way to track sectors in reverse; the sectors are linked with just a forward chain.
But if the sectors have been stored contiguously then it shouldn't be too hard to set up a procedure to retrieve the sectors in reverse, then come up with a way to play each sector in reverse.
That would be easy to make play backwards.
Playing back from SD might be trouble, as David says.
You could easily use an SRAM chip if you need more space though...
(record 15 seconds of CD quality audio to the output.mp3 file, then play it back in reverse)
You can then just toss this into a Bash script that loops and does anything else that you need to get done.
edit: BTW, it's really fun doing your game! I didn't realize that I made all those weird noises when I spoke, and I suppose it gives me a taste of what English sounds like to non-native speakers.
It might make more sense to partition the SD card into FAT and non-FAT sections and use lower-level code to copy a FAT sound file to the non-FAT partition as one monolithic block of data. Then that could be read in reverse quite easily. Or just dispose with a filesystem altogether if a single block of sound data is all that has to exist on the SD card.
Apparently, this is fixed:
http://forums.parallax.com/showthread.php/143130-FSRW-pread-question
If you can buffer the whole file, then it is a different matter... but, you'll need a lot of memory then.
Would it be possible to make a cluster address list ahead of time in RAM in order to avoid the performance hit? If so, you could traverse the clusters in reverse without having to scan from the beginning each time.
______________
OTOH, even with a performance hit, one could simply copy the file in reverse order before attempting real-time playback.
You could do that. The trick is that it will be more work then (o_O)!
You could get non-multi block access speeds. So, the same speed as my file system driver which is just enough to play a file.
I have a private function in my code that actually does this for you. You just give it a file name and it will give you the list of file clusters. Assuming the disk has 64 K clusters then the list will not be so large. 1024 longs for a 64 MB file.
reasonably sized buffers. Say, use a 16K buffer and read backwards
in chunks of 8K; half the buffer is playing and half the buffer is being
read into.
Assuming your cluster size is large (32k) and your sample rate is
small enough, this should be plenty fast. An 8K chunk comes in
pretty fast.
Just don't try to read backwards in small chunks (512 or less).
If your cluster size is small, then all bets are off.
If there will be any challenge, it will be getting a reliable write
(record); the SD card can stall for a fairly good amount of time on
any arbitrary write. It will be rare, but write delays of for instance a
half second are quite possible. The card is doing a *lot* of stuff
inside and once in a while you catch it out of erased blocks or
in the middle of a required data copy or some such. For this a
big buffer helps too. Indeed, it may be necessary to use a
larger buffer than fits in hub ram to reliably record without gaps.
This sounds like fun and some day I'll get a chance to play . . .
tom
but it does demonstrate recording and playing and backwards on a DEMOBOARD, and you decide if it's of any use.
If you use the Prop to play the sound backwards, then you would hear its evil plan for world donination mixed in ...
Yeah I'm at work, yeah its quiet ...
