NEWBIE Needs help for Motor Controller — Parallax Forums
Frankfern123Frankfern123 Posts: 35
edited 2013-05-28 12:40 in Propeller 1
Hi All. I need a schematic for a reversible 12 vdc motor controller that can handle up to 10 Amps for my project. Any help would be greatly appreciated.
Thank You in advance.
    edited 2013-05-26 11:35
    There are lots of designs on the web like this one. This was found by searching for "H-Bridge 12V 10A".
  • Frankfern123Frankfern123 Posts: 35
    edited 2013-05-27 06:32
    Thanks for the link. I do have a model K158 Bipolar stepper motor controller from KITSRUS. Do you know if I can use this to run a single 12 vdc motor bidirectionally with speed and stop function as well. Thats what i really need for this project. I'm assembling it on a Propeller Board Of Education board but was wondering if I should switch to the new activity board that programs in C. Regardless I'm still on a steep learning curve and will routinely ask stupid questions.
    Thanks in advance .............
    edited 2013-05-27 08:59
    This one can do 25A continuous with 35A surge.
    30A is pretty darn powerful. I use cheap L298N boards from ebay on several of my robots but they're only good for a couple of amps.
    Pololu has a bunch of H-bridge boards. They may have something you can use.
    If you search the Parallax forums (theres a link to Rich's search in post #1 of my index (see signature)) you'll likely find several h-bridge circuits. You could also search Letsmakerobots.com. I know there are several H-bridge circuits on that site.
    edited 2013-05-28 11:45
    Hi everyone, thanks for all the help. I found this link and I'm building it now. I think this may work out very well for my project.
    Need an opinion though, should I use optoisolators to drive this ???
    http://www.pyroelectro.com/tutorials/h_bridge_4_transistor/index.html
    You don't need Opto-Isolation, but I would place a 100k resistor to ground on both inputs as a safety precaution during 'floating' inputs. (i.e. during powerup) Since you are using a Propeller and the output of the I/O's are 3.3V, I would lower the 10k resistor on the inputs to 4.7k instead.
