Pressing Enter does not move to a new line — Parallax Forums
GenetixGenetix Posts: 1,774
edited 2013-06-06 07:19 in General Discussion
Am I doing something wrong? I can only type long paragraphs because I don't know how to make the cursor go to a new line. Usually you just hit Enter but this editor works different.
  • ElectrodudeElectrodude Posts: 1,685
    edited 2013-05-25 16:06
    What browser and what OS are you using? This forum software doesn't use a normal text entry box, and your browser probably isn't handling the fake one this forum uses properly.
  • xanaduxanadu Posts: 3,347
    edited 2013-05-26 10:17
    This is a Windows 8 / IE 10 / vBulletin issue, I have it too.
  • GenetixGenetix Posts: 1,774
    edited 2013-05-28 14:04
    I have Windows 7 and IE 10. Xanadu has the same problem and he's using Windows 8.
    edited 2013-05-29 01:34
    Sometimes, when I'm feeling adventurous I use IE10 :) It's not so bad I've posted a couple times with no enter key now. Improvise, adapt, and overcome run on paragraphs. Unfortunately, my other usual two browsers work perfectly!
    edited 2013-05-30 10:44
    I just noticed that the Refresh button seems to be missing from IE10. Perhaps now is a good time to start using Chrome.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-06-04 17:30
    I believe this is an IE 10 issue. The same thing happened on my main computer after IE 10 was installed. A couple weeks later I installed IE 10 on my laptop and it has been doing it ever since.
    Either press F5 or the icon is the up/down pointing green arrows next to the address bar.
    Other people are reporting IE 10 problems especially since it comes with Windows 8. I learned that pressing ALT displays the menu if that helps others.
