Brad's spin tool
I am an ubuntu user. I have tried using Brad's spin tool before and run across some problems with it. Firsts off it seems none of the drop down menues in the program works, nor the buttons on the unsaved file dialoug box.
The problem of course is that operating systems tend to move forwards and eventually application binaries start to fail as library versions change and such like.
Sadly in this case BST is a closed source program and it's author seems to have given up supporting it.
Have you looked into Simple IDE? I believe that is working for Spin development on Ubuntu.
Which version of bst are you using? I'm using version 0.19.3 without problems.
-Tor
