servo won't run counterclockwise or stop when delayed — Parallax Forums
RubyRobotRubyRobot Posts: 10
edited 2013-06-26 03:09 in Robotics
Dear people, I am working with the Robotics Shield Kit as an absolute beginner. I tried below code from Parallax (http://learn.parallax.com/node/188), but what I don't understand is, how does the servo know if it should run clockwise or counterclockwise rotation? Is it just the servoLeft or servoRight? So if I want to change the clockwise rotation to counterclockwise rotation, I just change servoLeft to Servoright? If so, I do not understand below code, because first both servos run cl.ockwise, then they should stop and run counterclockwise. I'm missing here how the direction of rotation is chnaged. Now I also have a problem with delaying the servos, because if I want the servo to stop I can use delay(3000), it doesn't delay. <code>/*
Robotics with the BOE Shield – ServoRunTimes
Generate a servo full speed counterclockwise signal with pin 13 and
full speed clockwise signal with pin 12.
#include <Servo.h> // Include servo library
Servo servoLeft; // Declare left servo signal
Servo servoRight; // Declare right servo signal
void setup() // Built in initialization block
servoLeft.attach(13); // Attach left signal to pin 13
servoRight.attach(12); // Attach right signal to pin 12
servoLeft.writeMicroseconds(1300); // Pin 13 clockwise
servoRight.writeMicroseconds(1300); // Pin 12 clockwise
delay(3000); // ..for 3 seconds
servoLeft.writeMicroseconds(1700); // Pin 13 counterclockwise
servoRight.writeMicroseconds(1700); // Pin 12 counterclockwise
servoLeft.writeMicroseconds(1500); // Pin 13 stay still
servoRight.writeMicroseconds(1500); // Pin 12 stay still
void loop() // Main loop auto-repeats
{ // Empty, nothing needs repeating
</code>
    edited 2013-05-23 06:56
    Hi and welcome to the forum. A few things to consider. The Arduino uses interrups to tend the servos so a delay() doesn't stop the servos, only execution of the program. To stop a servo you issue servo.writeMicroseconds(1500); which is the pulse width to stop a servo.
    This leads into your next question, how does a servo know to rotate clockwise or counter clockwise? The answer is that pulses are allowed to be between 1000 and 2000 wide. Pulses between 1000-1500 rotate one direction while pulses between 1500-2000 rotate the other direction. The difference between the centering pulse and your pulse is roughly proportional to the speed of rotation. I say roughly because servos have individual variations so the center pulse and the limits (1000) or (2000) differ from servo to servo. Generally you'll need to do some experiments to determine which values work best for your servos.
    If you still have problems let me know. BTW it's a really good idea to get a piezo speaker and add an output tone to the start of your program. Sometimes weak batteries cause a restart and your program only runs to the first servo pulse and restarts. It looks like subsequent servo manipulation calls don't work because the code never gets there. I've been bitten by this several times and I'm experienced with this stuff. Since the Arduino requires a higher source voltage than a BS2 it happens more frequently.
    edited 2013-06-05 09:02
    If the servo has not been centered it may also operate in one direction only and not stop.
  • Beau SchwabeBeau Schwabe Posts: 6,568
    edited 2013-06-05 10:03
    Also, double check the ground connection of your servo and make sure that it is sharing the same GND or Vcc connection. The 50/60 Hz main voltage is enough to trigger an ungrounded servo sometimes in a characteristic "only one direction".
  • RubyRobotRubyRobot Posts: 10
    edited 2013-06-07 15:02
    [HTML]Hi! First of all, thanks for your replies and explanations. I tried this code:
     Robotics with the BOE Shield – LeftServoClockwise
     Generate a servo full speed clockwise signal on digital pin 13.
    Servo servoRight;                             // Declare left servo
      servoLeft.writeMicroseconds(1300);         // 1.3 ms full speed clockwise
      servoRight.attach(13);                      // Attach left signal to pin 13
      servoRight.writeMicroseconds(1700);         // 1.3 ms full speed clockwise
    I expected the servo to clockwise and the other counterclockwise, then stop, then turn the other way.
    This is not what happened, both wheels went clockwise and the servo's did not stop and change direction.
    Maybe i have not centered the servo's correctly, because I have twisted the screwdriver, but the servo's were alreay still.
    For the connection to the GRN, see attached pics.
    I'm lost here :(
    Regards! Ruby
    [/HTML]
    640 x 480 - 123K
    640 x 480 - 129K
    640 x 480 - 101K
    edited 2013-06-07 15:09
    BTW Martin,
    Thanks for your suggestion about connecting a speaker!
    Regards, Ruby
  • John AbshierJohn Abshier Posts: 1,116
    edited 2013-06-07 15:53
    I think you need some time between the servoxxxx.writeMicroseconds to allow the servo to move.
    John Abshier
    edited 2013-06-07 17:24
    I'll second that. What the code is doing right now is turn one way, stop, turn the other way. But computers are fast compared to physical events, so from the servos point of view it only sees the last command.
    edited 2013-06-08 02:16
    [HTML]Hi Martin,
    My problem is still not solved, but I am understanding the concept of servo's better now. I should use the delay command if I want some command to be executed for a period of time. So, I wrote below code and tested it. The upper servo is turning (what i also expected it to do), but won't stop at the end. The other servo just turns one direction.
    Maybe I should center the servo's again, but besides twisting the screwdriver, I'm not really sure how to do it. Should it turn when I twist the screwdriver?
    <iframe width="640" height="360" src="http://www.youtube.com/embed/adhzVuhXTTQ?feature=player_detailpage&quot; frameborder="0" allowfullscreen></iframe>
      delay(1000);                               // ..for 1 seconds
      servoRight.attach(13);                     // Attach right signal to pin 13
    [/HTML]
    edited 2013-06-08 07:34
    Thanks for posting the video as it illustrated your problem nicely. It looks like the right servo changes directions, while the left always runs forward, and neither stops. I would put a debug tone before each delay so you can match behaviors with the robot's physical actions.
    I can't try your program right now, but later this weekend I should have a chance. My servos are centered so we can eliminate that variable.
    edited 2013-06-08 09:08
    At the beginning of setup servoLeft is attached to pin 13. Who knows what happens to servoRight? After 3 seconds servoRight is attached to pin 13. Both servos cannot be attached to the same pin.
    John Abshier
  • ercoerco Posts: 20,257
    edited 2013-06-08 19:30
    Good eye, John!
    Funny, the OP's code in his very first post shows the right servo on pin 12. Something got mashed up after that.
    edited 2013-06-09 03:19
    Since i don't have a speaker to test if all code is executed, I tried with the leds. When the servo's start turning, the leds are on. When the servo's should stop, the leds go off.
    I taped it: http://youtu.be/39YMWulgSxU
    It looks like only the first 8 lines of code is executed:
    pinMode(13, OUTPUT); // Set digital pin 13 -> output
    pinMode(12, OUTPUT); // Set digital pin 13 -> output
    servoRight.attach(12); // Attach right signal to pin 13
    digitalWrite(13, HIGH); // Pin 13 = 5 V, LED emits light
    digitalWrite(12, HIGH); // Pin 13 = 5 V, LED emits light
    Now, what can one do, when code is not being executed?
    delay(3000); // ..for 1 seconds
    digitalWrite(13, LOW); // Pin 13 = 0 V, LED no light
    digitalWrite(12, LOW); // Pin 13 = 0 V, LED no light
    edited 2013-06-09 04:07
    From that code it looks like the LED's are on the same pins are your servos. That won't work because the Servo library will conflict with your high and low commands for the LEDs.
    edited 2013-06-09 04:43
    Ah, makes sense to me! I took the example for the leds from Parallax: http://learn.parallax.com/node/176
    But there are two pins with number 12 and two pins with numbver 13, how should I change my code, so my test would be correct?
    640 x 480 - 109K
    edited 2013-06-09 05:54
    RubyRobot wrote: »
    Move the LED resistors over to pins 10 and 11, then changed the code which changes the LED's to those pins.
    edited 2013-06-09 12:06
    I changed the leds to pin 10 and 11:
    pinMode(11, OUTPUT); // Set digital pin 13 -> output
    pinMode(10, OUTPUT); // Set digital pin 13 -> output
    digitalWrite(11, HIGH); // Pin 13 = 5 V, LED emits light
    digitalWrite(10, HIGH); // Pin 13 = 5 V, LED emits light
    digitalWrite(11, LOW); // Pin 13 = 0 V, LED no light
    digitalWrite(10, LOW); // Pin 13 = 0 V, LED no light
    Now the leds do their work, only the servo's do not. They turn, and just keep doing that.
    Here's the video: http://www.youtube.com/watch?feature=player_detailpage&v=lNvOMya-BKw
    No idea what I could try next :(
    edited 2013-06-09 19:30
    Rather than use LED's I tweaked your program to use the serial output window. Do you know how to use that? You open it by going to the "Tools" menu and select "Serial Monitor". This allows the Arduino to print to your PC's screen and gain insight into what the code is doing. The code below is your code cleaned up a bit, but it spins the wheels opposite directions, stops, reverses the opposite directions, then stops again. In my monitor window I see this output.
    At head of Setup.
    Pulse servos with 1300 for 3 seconds.
    Pulse servos with 1500 for 3 seconds
    Pulse servos with 1700 for three seconds
    stop servos with a 1500 pulse.
    Tweaked program below:
      Serial.begin(9600);
      Serial.println("At head of Setup.");
      Serial.println("Pulse servos with 1300 for 3 seconds.");
      Serial.println("Pulse servos with 1500 for 3 seconds");
      Serial.println("Pulse servos with 1700 for three seconds");
      // servo stop
      Serial.println("stop servos with a 1500 pulse.");
    Since this code works on my robot, if it produces bad behavior on yours we know that either your servos need centering, or your batteries have a problem.
    edited 2013-06-10 11:43
    Martin_H wrote: »
    I believe in that example the LEDs are intended to provide a visual feedback that the servos are actually getting the pulses. If you move the LEDs to different pins that would defeat that purpose. In the most basic sense the LEDs help troubleshooting by narrowing down the cause of servos not moving to the I/O pin/code or the servos being bad/miswired/not powered/etc.
    However, you should not be using HIGH/LOW commands on the pins sharing the servos/LEDs to force them on/off.
    edited 2013-06-11 00:48
    I tested the code Martin gave me, but although the output is printed, the servo's don't change directions or stop at all. The problem must be with the servo's and I will try centering them again.
    Just wondering if it would be better to clear the servo's from all the code that I've been sending? How can I do this? Should I use some kind of reset command, because now they are turning as soon as they get power.
    About there being two pins with number 12 and 13, why is that? I understand that I should not be using HIGH/LOW commands on the servo pins, but what if I'm out of pins, and need to use them all, how can I identify them? I just would like to understand :)
    Regards, Ruby
    edited 2013-06-11 02:41
    RubyRobot wrote: »
    Servos don't have a memory, so each time you upload a new program they'll respond to it. If your servos don't change directions then it sounds like they need centering.
    RubyRobot wrote: »
    If you look at the edge of the BOE shield next to the servo headers you'll see the numbers 13 12 11 10. The signal pin on those headers is connected to digital headers 13 12 11 10 next to the breadboard. So when you are not using servos you can hook LED's to those headers. The servo headers are there to make connecting easier for devices that use them.
    edited 2013-06-11 09:52
    The servo headers on the Board of Education are connected to P12 through P15. This provides a convenient way to connect servos and other devices to these I/O pins. But whether you're connecting something at the servo header or at the I/O socket, if the pin is in use by something, you can't use it for something else. As I mentioned previously, the LEDs connected to the same ports are just there to provide a visual indication of the pulses being sent to the servos. You don't need to clear the servos of any data you've sent. The servos just respond to pulses by moving based on the width of the pulse. There is no data to clear. Centering is very important.
    edited 2013-06-11 12:03
    Chris, he's using the BOE Shield with an Arduino, so the servo headers are connected to 10 through 13.
    edited 2013-06-11 14:03
    Martin_H wrote: »
    You're right...trying to reply to the forums and getting tech calls at the same time (on the BoE). The main thing I was trying to emphasize was that why the I/O pins are shared and why the LEDs should be plugged into the same ports used by the servos. I didn't want the OP thinking that was the issue when it is a useful debugging tool.
    When I watched one of the videos I could have sworn that the LEDs were pulsing and then when they stopped one of the servos kept going. If the servo is going without receiving pulses that is not proper operation.
    edited 2013-06-14 00:59
    A big thank you again for Martin and Chris!
    I do understand why you cannot connect a servo and a led to the same port number. What I do not understand is why not give all the ports a diffrenet number, so they can all be used. Seems a bit unlogical to me, but maybe in time I'll see the benefit of this solution.
    If I'm digging to deep, just let me know, but if servos don't have a memory, how do they "remember" the uploaded program, once it gets disconnected from my computer?
    I will center the servo's again. Now as I switch on the power, they start turning. So what I'll do is, put on the power [the servo's start turning]. While they turn I twist the screwdriver until the servo's stop turning. This is how I understood centering. Just need to know if that is correct, so I don't break my servo's.
    Regards, Ruby
    edited 2013-06-14 07:03
    RubyRobot wrote: »
    All the Arduino pins are already allocated on the BOE shield, there aren't any other pins.
    RubyRobot wrote: »
    The Parallax tutorial site will explain:
    http://learn.parallax.com/node/185
    Note that the sketch on that site only signals one servo. I updated it below to center both servos.
     Robotics with the BOE Shield &#8211; RightServoStayStill
     Transmit the center or stay still signal on pin 12 for center adjustment.
    void setup()                                 // Built-in initialization block
      servoRight.writeMicroseconds(1500);        // 1.5 ms stay still signal
      servoLeft.writeMicroseconds(1500);        // 1.5 ms stay still signal
    edited 2013-06-25 23:59
    Hey, good news: I GOT IT WORKING!!!!
    I centered the servo's they way i thought it had to be done, uploaded your code (added some lines) and it did exactly what I expected.
    Thanks a lot for your help!!
    Regards, Ruby
    Robotics with the BOE Shield – RightServoStayStill
    delay(3000);
    servoRight.writeMicroseconds(1700); // 1.5 ms stay still signal
    delay(3000);
    delay(3000);
    servoRight.writeMicroseconds(1300); // 1.5 ms stay still signal
    delay(3000);
    delay(3000);
    servoLeft.writeMicroseconds(1700); // 1.5 ms stay still signal
    delay(3000);
    delay(3000);
    servoLeft.writeMicroseconds(1300); // 1.5 ms stay still signal
    delay(3000);
    Great, glad to hear it.
