Ulcd-32ptu — Parallax Forums
Ulcd-32ptu
PodionPodion Posts: 90
edited 2013-05-23 07:43 in Propeller 1
Hello
Im using the ULCD-32PTU in visi genis mode whit a prop and a can't receive data from the screen. I'm able to send data to it and it work fine.
Do you have some example code to receive data from a input on the screen.
The screen send 07 0D 00 00 38 32 I'm only interests to receive the 00 and 38 these are the msb and lsb.
Wen I check the pst I receive all kind of hex value but not the 00 38
Thank
    No example code. This is a very complex product, particularly when you're using the ViSi-Genie mode. You're just going to have to slog through the extensive 4D Systems manuals and compare what the manuals say to what information you're seeing. From the Propeller's standpoint, it's just a serial device and that part of the communications seems to be working. If you want some further help, you're going to have to provide much more information about what you're trying to do, your code (including the Visi-Genie stuff), and a diagram of your wiring.
