Power/Connection for Micro Servo
Does anyone have a clue as to how I can power these micro servos from a Prop Boe Board? I am not sure of the voltage or the pinning arrangement and want to ask before I fry anything. http://www.ebay.com/itm/170971634744?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
The math should be the same.
1500us should center the servo, 1000us should be full (depending on servo) clockwise rotation and 2000us should be full counterclockwise rotation.
Some servos can go well beyond the 1000us and 2000us limits. If you have a QuickStart board, you can use my QuickStart servo tester to check where the endpoints are.
HobbyKing's HXT900 servos can turn a full 180 degrees but you need to use non-standard pulse lengths to get them to turn that far.
