TCS3200 emissive response
In the documentation for the TCS3200 it has a graph showing the relative response for emissive light. I'm trying to figure out how to compensate for the differences between the photodiodes when using a constant time across all 4 of the photodiodes. For example, if I'm using 100 as the time for all 4, how do I determine, based on the chart, how to adjust the color photodiodes to balance out their relative responsiveness and get an accurate reading of their values in that time of 100? Thanks.
It's much simpler just to do a white balance if you have a known white subject, though.
I have a high quality white LED light; can I direct that into the sensor and calibrate the colors? The goal would be to just make them equal, right?
Yes, so long as it uses broad-spectrum fluorescence to generate the white light and not just RGB LED elements. An incandescent bulb would be better, though, since it has a smooth, even spectrum.
Right.
I figured out the area below each color's curve first. I did so by counting the squares and fractions of squares thereof. I found 18 for red, 15 for green, and 13 for blue. I then took readings under a broad spectrum light bulb. I multiplied the responses by the inverse of the above numbers.
The results were a little off, as my method of area estimation was, well, estimation. I made some adjustments using the light and found that 17.5 for red, 14.5 for green, and 13 for blue evened out the responses nicely. When I took the inverse I got .057 for red, .069 for green, and .077 for blue. I don't know why I needed to do this (maybe someone can explain why; I imagine it has to do with the chart being fractions of 1, or something), but I then multiplied them all by 10, because otherwise the responses were way too low relative to the clear response.
The final result was .57 for red, .69 for green, and .77 for blue. This appeared to balance the responses pretty well under the light, made them all make sense relative to the clear response (in total the 3 equaled about 75% of the clear response) and made sense based on the areas under each curve that I calculated.
Hope this helps anyone needing to calibrate based on emissive light.
Ben
