Measuring high voltage using basic stamp?
Hello.
I need to measure with say 1% accuracy voltage from 200 to 330v. As basic stamp manual says, you can use capacitor charge/discharge time to determine the input voltage, but my problem is, that voltage source is charge pump, which delivers very little current, so, I will have to use very high impedance voltage divider resistor, which will cause measuring capacitor to charge slowly, which itself will cause very low integration speed. Any solutions?
You want 1% accuracy and I don't think you'll get that using RCTIME. Basic Stamp timing is somewhat temperature sensitive. It's certainly sensitive to supply voltage and that's not regulated to 1%. You will need an external analog to digital converter with an external reference source and you'll need to supply that reference and make sure it's accurate to at least 1%.
