Boe Bot Gui Software
I recently decided to down load the Boe Bot GUI soft ware to 30 laptops so that i could use the Boe Bots with younger students using the GUI program.
I am using Dell 910 mini's with XP operating system. some computers are 8Gb but others are 16Gb hard drives.
I have also loaded Scribbler 1 and S2 software as i also use these Robots.
On four of the computers all programs work perfectly without any issue's However on 2 computer although it downloads PBasic to the Boe- Bot when using the same cable and Boe Bot it will not download the GUI program. It states either invalid Port or No Robot. I have re installed the software without success also on these 2 computers i cannot download to the Scribblers either.
I have even used the authorised Parallax Cable and adaptor without success.
I constantly have USB cable issues which is why i purchased some R340 cables from China as these seemed to fail less than the Parallax product.
I am keen to resolve this issue as my older Scribbler 1's are getting past their best and i would be grateful for any help, support or idea's you may have.
Pat
patjamison@hotmail ,com Belfast Northern Ireland.
Pat
Pat
I also loaded the Boe- Bot GUI software onto my 35 Toshiba M2 laptops on 32 i had no problem and i have all the Parallax software and cables working as advertized but on 3 the GUI will not work.
I accept that i just might have to live with that.
The Parallax Cable and adapter are not particularly user friendly, i have had to use Electrical installation tape to keep them together as younger students keep pulling the cable out of the adapter which eventually breaks the housing. I bought the R340 cables from China and although they do cause some problems the final attrition rate and cost is not as high as replacing the Parallax cable and adapter, Its a pity that Parallax don't make a molded version of the USB/ R232 cable.I have only just taken delivery of 60 cables from China and 7 were defective on receipt.
Thanks for all your help i will let you know if the cloning of the hard drive works.
Best Wishes
Pat
I then opened the GUI program and it worked as advertised, I am pleased this has now worked and hope no one else will ever have to experience the frustration of invalid port again.
Many thanks to all who helped.
Regards
Pat
