help me about tcs230 color sensor
hi everybody ı am programming pic 16f877a for my thesis and ı need to your help. I will use rgb sensor from texas ins. Tsc 230
and ı need to source code and ı dont have any experience how do you programming or how should ı start in program. please explain me and step by step or just help me to begin my program. Thanks and regards. mikro c 2*16 lcd 16f877a tcs230 rgb sensor (mikroc)
Welcome to the forums!
Duplicate posting are not allowed and you other will probably be deleted.
Here is some basic BS2 code:
http://www.parallax.com/dl/docs/prod/datast/TCS230.pdf
Since this is a Parallax forum we only support Parallax products.
There are also some Arduino codes on the net that could also be deciphered.
You can check out these threads to start with: “http://forums.parallax.com/showthread.php/139677-TCS-3200-DB-Color-Sensor-Module “ and “http://forums.parallax.com/showthread.php/136258-Code-for-using-a-TCS3200-with-Arduino-and-a-question ”.
