XMM boot options? — Parallax Forums
XMM boot options?
RaymanRayman Posts: 16,455
edited 2013-05-13 12:50 in Propeller 1
Maybe this is an easy question, but I don't know where to look for an answer...
I have some code running in xmmc, xmm-split, and xmm-single modes.
But, this is being programmed over serial interface.
How can I make these bootable?
Can everything be in flash?
Or, maybe that doesn't work for xmm-single mode?
Do you already have it rigged so that it can boot this from uSD card?
    edited 2013-05-13 12:44
    Rayman wrote: »
    Just use the -e option to program the EEPROM with a loader that can start your program from flash. That should work with xmmc or xmm-split. For xmm-single you'd have to load from an SD card.
  • RaymanRayman Posts: 16,455
    edited 2013-05-13 12:49
    How do you load xmm-single from SD card?
    Rayman wrote: »
    Use the -l option of propeller-load. Try typing "propeller-load -?" to get a full list of options.
