Wireless Prop Programming?
Hey All,
I'm wondering if I can program a prop across a wireless ethernet bridge? I have a couple of USB to Ethernet adapters that I use now for some distance programming, but I'd like to eliminate the cable. Or any other method that could program a prop within about 100 feet or so.
Thanks!
Jonathan
Thanks!
Jonathan
Jonathan
There is an article on programming via XBee here http://www.parallaxsemiconductor.com/an007.
Even if the USB-ethernet bridge twiddles the reset line properly, timing is critical and ethernet introduces all kinds of latencies that the process can't tolerate. It's not even the RF link so much as the ethernet layer that's the problem.
I've successfully used a self-contained wireless USB hub with the FTDI on the far end of the wireless link, those seem to use a dedicated RF protocol that does a better job of controlling the timing.
