OBC Jeff , can you help me please
skylight
I've been trying to follow the bluetooth tutorial here:
http://www.gadgetgangster.com/news/56-jeffs-shop/534-bluetooth-howto.html
I've managed to pair the module and have got as far as step 5, step 6 shows the screen with the allocated com ports, I don't get this screen showing the com ports, just that the module has connected successfully.
When I try to look at the properties of the linvor module I get an "access denied" so am unable to work out what port is allocated
Have you come across this and if so what was the work around?
Thanks for any help you may be able to give
Also, that was the old Tutorial based on XP. If you are running the newer Windows 7 you'll want to look at this one.
http://propellerpowered.com/shop/?page_id=1748
It includes a tool or two as well to help you get things communicating.
Jeff
You'll find some additional utilities which will be useful on the new page as well.
Jeff
