Missing first byte stored in a buffer. Need some help with this. — Parallax Forums
Don MDon M Posts: 1,654
edited 2013-05-01 19:13 in Propeller 1
I am receiving in some data into a buffer. For some reason I am missing the first byte. It must be the way I have this loop structured but can't figure why it won't work.
I can see the data on the analyzer so I know it's there but somehow my indexing is off by one. The buffer is 32 bytes. The final check byte has 9th bit set so that is the reason for the $1_00 check.
  inx := 0
  s := serial.rx_time(20)
  if s > -1
    'inx := 0
    chksum := s
    buffer[inx] := s
    repeat
      s := serial.rx_time(5)
      if (s & $1_00)
        chksum &=  $0_FF
        if (chksum == (s & $0_FF))
          pollack
          seq++
          term.str(string("ID: ",13,10,03))
          quit
      chksum += s
      buffer[inx] := s
      inx ++
  else
    term.str(string("No Response to ID",13,10,03))
    seq := 4
  repeat inx from 0 to 28
    term.tx(byte[@buffer][inx])
    term.tx(32)
  term.tx(13)
  • Don MDon M Posts: 1,654
    edited 2013-05-01 18:23
    If I add a "term.tx(s)" in a couple places I see on PST what I need but for some reason the buffer misses the first byte.
      if s > -1
        chksum := s
        buffer[inx] := s
        term.tx(s)     '<<< This shows the first byte. Why isn't it stored in buffer?
        repeat
          buffer[inx] := s
          if (s & $1_00)
            chksum &=  $0_FF
              pollack
              seq++
              quit
          chksum += s
          buffer[inx] := s
          term.tx(s)
          inx ++
    edited 2013-05-01 18:31
    It looks like it should work. Try changing inx := 0 to inx := 1 and increasing the buffer size by one to see if the first byte is lost in the input loop or output loop.
    edited 2013-05-01 18:38
    No that didn't help.
    What I don't understand is if I can see the first byte from the first term.tx(s) then why isn't this same byte stored to buffer[idx] when idx starts at 0?
    I can do term.tx(byte[@buffer][0]) and I see the second byte that is received not the first. Weird....
  • juropjurop Posts: 43
    edited 2013-05-01 18:42
    Try changing
          chksum += s
          buffer[inx] := s
          inx ++
      else
    with
           chksum += s
           buffer[++inx] := s
      else
    edited 2013-05-01 18:46
    jurop wrote: »
    Try changing
          chksum += s
          buffer[inx] := s
          inx ++
      else
    with
           chksum += s
           buffer[++inx] := s
      else
    Nope. Still doesn't show correct first byte from buffer.
    edited 2013-05-01 19:09
    Ok I got it to work.
    Seems as though inx was not being advanced after the first byte stored. See below.
      inx := 0
      if s > -1
        chksum := s
        buffer[inx] := s
        inx++               '<<<< Here is where my problem was....
        repeat
          if (s & $1_00)
            chksum &=  $0_FF
              pollack
              seq++
              quit
          chksum += s
          buffer[inx] := s
          inx++
      else
        seq := 4
    This works too...
    inx := 0
      if s > -1
        chksum := s
        buffer[inx++] := s
        repeat
          if (s & $1_00)
            chksum &=  $0_FF
              pollack
              seq++
              quit
          chksum += s
          buffer[inx++] := s
      else
        seq := 4
