Solderless Bullseye Electret Microphone
Sometimes the obvious isn't... I have a small quantitiy of Electret Microphones--specifically [h=1]TOM-1545S-C33-R[/h]I simply am unable to figure out how to attach this to a PCB board.
There must be a holder of some sort... Nice little device, but I can't fgure it out.
Anyone care to wade in?
http://delphi.com/connectors/assets/product_brochure/Delphi%20Bulls-Eye%20Subminiature%20Connectors.pdf
The link above is from a quick search for the connectors on google. These may not suit your needs.
Digikey carries this component, I would give them a call. They probably have the connector for it as well
http://www.digikey.com/product-detail/en/WM-63GNT335/P11960-ND/521099
tried searching for "electret mic pressure contact" but couldn't come up with anything showing how it's assembled............
http://www.digikey.com/product-search/en?FV=fff4000b,fff80048,fffc029c
Just use the filter under termination select bullseye and your mic is 3rd on the list.
Yes, they are intended to be 'solderless' replacements in existing microphone housings -- but seem to accept a bit of solder without any problem.
