PINK and Internet Access
I have my PINK all set up and ready to go. I understand that the default port is 80 on the PINK web server. However, when I use port forwarding on my Router to forward port 95 to the PINK's IP address it is not working. Do I maybe need to add the PINK in IIS on my default Server?
When trying to access the PINK from the internet, you must use the IP assigned by your ISP with the port forward configured in the router. The IP assigned by your ISP can be found in your router or by going to the following page, http://www.whatsmyip.org/. Type the IP and port in your browser address bar and press enter.
