Infrared Line Follower Kit (#28034)
Jim the Hermit
I'm making a robot (almost) from scratch- how low to the floor is this sensor suppose to be? Let's say; indoors with a black floor and a white line or white floor with a black line.
However, lower is better, and you will get more accurate sensor readings, if you stay less than 1/4" above the floor.
Also, don't forget you can adjust the sensitivity a little bit using the variable resistor built onto the sensor PCB.
Since you are building from scratch, you should try to make it adjustable if at all possible.
I did this with my StingRay, as shown in this post here...
-Tommy
