Help With Initializing SSD1963 4.3inch 480x272 pixel LCD. Simple interface GUI — Parallax Forums
Igor_RastIgor_Rast Posts: 357
edited 2015-03-17 19:37 in Propeller 1
After spending allot of time trying to get this thing to work jumping in on other treads . Thought it was time to start my own tread.
As maybe you aleady catched it , I was having some trouble initializing the display , Started out with the schematics and code from Dr_A and Average Joe . They did some pretty awesome work with some LCD modules . and i got the best help possible someone could ask , Thanks again Dr_A and Average Joe. But I still havent got it to work ,
Broke down the schematic to an absolute minimun , Connecting the 8 data lines for a 8 bit bus , the other 8 data lines from the LCD are pulled high with a 10k resistor . and there are some control lines . connected directly to the prop pins .
Just wanting to get the white noise on the display for a start .
First I thouth the SSD1963 controller must be broken , But now I have a new one that does exactly the same , So its got to be something else .
Pretty sure Im just not seeing it , So any help at all is realy apriciated .
the spin code used now looks like below
_clkmode      = xtal1 + pll16x                        ' use crystal x 16
  _xinfreq      = 5_000_000                             ' 5Mhz crystal
  _1ms      = 1_000_000 /     1_000                     ' Divisor for 1 ms
CON
    CS_PIN = 10
    WR_PIN = 11
    RS_PIN = 12
    REST_PIN = 13
PUB Main |i
  outa[CS_PIN]~~
  outa[WR_PIN]~~         'exclusive for SRAM WR Pin .. LCD Shares Clock_pin with Counters
  outa[RS_PIN]~~
  outa[REST_PIN]~~
  outa[7..0]~~
  dira[CS_PIN]~~
  dira[WR_PIN]~~
  dira[RS_PIN]~~
  dira[REST_PIN]~~
  dira[7..0]~~
 pause1ms(50)
Start_SSD1963
PUB LCD_RS_High
  outa[RS_PIN]~~
PUB LCD_CS_High
    outa[CS_PIN]~~
PUB LCD_RESET_High
  outa[REST_PIN]~~
PUB LCD_WR_High
    outa[WR_PIN]~~
PUB LCD_RS_Low
  outa[RS_PIN]~
PUB LCD_CS_Low
    outa[CS_PIN]~
PUB LCD_RESET_Low
  outa[REST_PIN]~
PUB LCD_WR_Low
    outa[WR_PIN]~
PUB Bus8bit(data)
  outa[7..0] := data
PUB Lcd_Write_Com(adresslong)
    LCD_RS_Low
    LCD_write_bus(adresslong)
PUB Lcd_Write_Data(adresslong)
    LCD_RS_High
    LCD_write_bus(adresslong)                               ' send out the data
PUB Displaycmd(c,d) ' instruction in one method
    Lcd_Write_Com(c) ' send out a word
    Lcd_Write_Data(d)
PUB LCD_write_bus(lcdbyte)
    bus8bit(lcdbyte)
    LCD_WR_Low
    LCD_WR_High
PUB pause1ms(period) | clkcycles
'' Pause execution for period (in units of 1 ms).
  clkcycles := ((clkfreq / _1ms * period) - 4296) #> 381     ' Calculate 1 ms time unit
  waitcnt(clkcycles + cnt)                                   ' Wait for designated time
'' DISPLAY SETTINGS
DAT
   VDP        long  271
   HDP        long  479
   HT         long  531
   HPS        long  43
   LPS        long  8
   VT         long  288
   VPS        long  12
   FPS        long  4
   HPW        long  10
   VPW        long  10
PUB Start_SSD1963
    LCD_Reset_High
    pause1ms(5)
    LCD_Reset_Low
    pause1ms(5)
    LCD_Reset_High
    LCD_CS_High
    LCD_WR_High
    pause1ms(5)
    LCD_CS_Low
    Lcd_Write_Com ($00E2)       '($00E2)                             ' //PLL multiplier, set PLL clock to 120M
    Lcd_Write_Data($002D)       '($0023)                             ' //N=0x36 for 6.5M, 0x23 for 10M crystal ' $21??
    Lcd_Write_Data($0002)       '($0002)                             '
    Lcd_Write_Data($0004)       '($0054)                             ' dummy byte?
    Lcd_Write_Com ($00E0)       '($00E0)                             ' // PLL enable
    Lcd_Write_Data($0001)       '($0001)                             ' set pll
    pause1ms(1)
    Lcd_Write_Com ($00E0)       '($00E0)                             ' pll                         '
    Lcd_Write_Data($0003)       '($0003)
    pause1ms(5)
    Lcd_Write_Com ($0001)       '($0001)                             ' // software reset
    pause1ms(5)
    Lcd_Write_Com ($00E6)                             ' //PLL setting for PCLK, depends on resolution
    Lcd_Write_Data($00ff)                             '
    Lcd_Write_Com ($00B0)                              ' //LCD SPECIFICATION
    Lcd_Write_Data($0000)                             '
    Lcd_Write_Data((HDP>>8)&$00FF)                    ' //Set HDP 'hps??
    Lcd_Write_Data(HDP&$00FF)
    Lcd_Write_Data((VDP>>8)&$00FF)                    ' //Set VDP 'vps??
    Lcd_Write_Data(VDP&$00FF)
    Lcd_Write_Com ($00B4)                             ' //HSYNC
    Lcd_Write_Data((HT>>8)&$00FF)                     ' //Set HT
    Lcd_Write_Data(HT&$00FF)
    Lcd_Write_Data((HPS>>8)&$00FF)                    ' //Set HPS
    Lcd_Write_Data(HPS&$00FF)
    Lcd_Write_Data(HPW)                               ' //Set HPW
    Lcd_Write_Data((LPS>>8)&$00FF)                    ' //Set HPS
    Lcd_Write_Data(LPS&$00FF)                         '
    Lcd_Write_Com ($00B6)                             ' //VSYNC
    Lcd_Write_Data((VT>>8)&$00FF)                     ' //Set VT
    Lcd_Write_Data(VT&$00FF)
    Lcd_Write_Data((VPS>>8)&$00FF)                    ' //Set VPS
    Lcd_Write_Data(VPS&$00FF)
    Lcd_Write_Data(VPW)                               ' //Set VPW
    Lcd_Write_Data((FPS>>8)&$00FF)                    ' //Set FPS
    Lcd_Write_Data(FPS&$00FF)                         '
    Lcd_Write_Com ($00BA)                             '
    Lcd_Write_Data($0005)                             ' //GPIO[3:0] out 1
    Lcd_Write_Com ($00B8)                             '
    Lcd_Write_Data($0007)                             ' //GPIO3=input, GPIO[2:0]=output
    Lcd_Write_Data($0001)                             ' //GPIO0 normal
    Lcd_Write_Com ($0036)                              ' //rotation
    Lcd_Write_Data($0021)                              ' 3 is 180
    Lcd_Write_Com ($00F0)                             ' //pixel data interface
    Lcd_Write_Data($0003)                             ' 16 bit / 565
    pause1ms(5)
    Lcd_Write_Com ($0029)                              ' //display on
    Lcd_Write_Com ($00d0)                              ' //dynamic backlight
    Lcd_Write_Data($000d)
    Lcd_Write_Com($002c)
    LCD_RS_High
and the c example that came from the lcd
[code]#include <reg51.h>
#include <intrins.h>
#include <font\font.h>
#include <sys\sys.h>
#include <lcd\lcd.h>
/* http://ttmcu.taobao.com
  • average joeaverage joe Posts: 795
    edited 2013-04-19 20:12
    Igor,
    Sorry I have not had a chance to reply. Very busy as of late. Maybe high byte needs pull-downs instead of pull-ups? I would try this first. If I get a chance, I'll try to take a look at your code. No promises though.
    A side note, I've been revising the Touchburger and will be using different memory chips :http://www.digikey.com/product-detail/en/IS62WV51216BLL-55TLI/706-1048-ND/1555421 These might be of interest to you as well. Glue logic will be replaced with CPLD. More info when testing complete!
    Good luck!
  • Igor_RastIgor_Rast Posts: 357
    edited 2013-04-20 04:18
    @Average joe
    I have tryied pulling the hi bytes , Up and down , both with the same non working result .
    Beeing verry bussy also , I have yet to jump into reading the datasheets again to try to find more things wrong ,.
    The new memory doesnt seem to bad , but what are the advantages over having 2x a byte SRAM .
    Think ill see that when you let some more info on that :p
    the CPLD, Never heard of that before till now , taking its going to replace the counters etc , so less glue logic is always a good idea
    did find some nice explination about CPLD here
    but I think ill have to see that and schematics before I could understand it , in the range of an fpga device , sounds logic to mee
    Ill try following your posts. Busy day today . probably tomorrow ill give it a new shot to get the screen to ini..
    Your the best Average Joe , Thanks . :thumb:
    OK, I was shaking the screen a bit . Now it looks like i Do have the Inni . Yuppiejeeee
    Dammm I have to runn no more time for now , Ill get back to it ASAP .
    a shot of it
    Next op . Drawing something on it :p
    1024 x 768 - 115K
    1024 x 1365 - 155K
    edited 2013-04-20 07:40
    Woot! Got it!
    The advantage of using the new memory is two-fold. Should simplify logic and replaces 2 chips with one.
    Gotta run, post schematic and code!
    edited 2013-04-22 16:39
    Ok. So this is how it works .
    powerd with 3.3 volt (at the moment, sd card needs 5v)
    on the lcd module I removed the R4 resistor , and I bridged J1 and J3 to make it work ,.
    From the LCD connect D0-D7 to P0-P7 of the propeler
    D8-D15 are pulled low with a 10k Resistor
    chose any 4 more pins for CS_PIN , WR_PIN , RS_PIN, REST_PIN to controll the lcd .
    And now you have the simplest connection of the lcd module to the propeller . Verry slow interface *** a result ,
    But I did get it to INNI . That was the main problem before .
    the settings are set now for a 8bit color pixel , and a 8 bit bus .
    so need to change those back before trying to make it work with a 16 bit bus,
    The fix to what was wrong before was that I was only toggeling WR to get the data in , forgetting CS
    EDIT: On second thouth , I think Ill just select the lcd first by pulling CS low , and toggle only WR . it was like that in the schatic also so sould work out fine
        bus8bit(lcdbyte)
    '    LCD_WR_Low
    '    LCD_WR_High
        LCD_WR_CS_Low                                          ' send out the data
        LCD_WR_CS_High
    Ill be moving back to the SRAM pretty soon to get it running faster . still some things not realy happening like I want .
    trying to figure out why ,.
    e.g. trying to get a full screen of 1 color causes the display to start to show fuzzy image , see vid 2
    did get the screen filled up with blocks without it getting fuzzy (vid1) , ?something there ?
    and average joe comming up with a brilliant solution to minimize the logic ic needed to run the SRAM.
    Hopefully he is willing to share pretty soon.
    in the mean time ill be building back the schematic I had before to see if it will work now . If I can find the time
    wish me luck :tongue:
    TIP: Disconnect the Serial programmer after loading in a new program may be a verry helpfull thing , *** the LCD modules get just enoug current from the usb to keep the memory running even if the board is turned off.
    Hoping to get it working with the Touchburger code , so I dont have to reinvent the weel for getting a image from sd card etc. will take its time off course
    Full Code
    CON
        CS_PIN = 10
        WR_PIN = 11
        RS_PIN = 12
        REST_PIN = 13
    PUB Main |i
      outa[CS_PIN]~~
      outa[RS_PIN]~~
      outa[REST_PIN]~~
      outa[7..0]~~
      dira[CS_PIN]~~
      dira[WR_PIN]~~
      dira[RS_PIN]~~
      dira[REST_PIN]~~
      dira[7..0]~~
      pause1ms(500)
      INNI_SSD1963           ' Initialize the LCD , should show some random noise on the LCD
    ' Full_Screen_Fill
      Fill_screen_Squares
        waitcnt(clkfreq + cnt)
     repeat
    PUB LCD_RS_High
      outa[RS_PIN]~~
    PUB LCD_CS_High
        outa[CS_PIN]~~
    PUB LCD_RESET_High
      outa[REST_PIN]~~
    PUB LCD_WR_High
        outa[WR_PIN]~~
    PUB LCD_RS_Low
      outa[RS_PIN]~
    PUB LCD_CS_Low
        outa[CS_PIN]~
    PUB LCD_RESET_Low
      outa[REST_PIN]~
    PUB LCD_WR_Low
        outa[WR_PIN]~
    PUB LCD_WR_CS_Low                                          ' send out the data
        outa[WR_PIN]~
        outa[CS_PIN]~
    PUB LCD_WR_CS_High
        outa[WR_PIN]~~
        outa[CS_PIN]~~
    PUB Bus8bit(data)
      outa[7..0] := data
    PUB Bus6bit(data)
      outa[7..2] := data
        LCD_RS_Low
        LCD_RS_High
        Lcd_Write_Data(d)
        bus8bit(lcdbyte)
    '    LCD_WR_Low
    '    LCD_WR_High
        LCD_WR_CS_High
    PUB LCD_write_Colorbus(lcdbyte)                            'used to send pixel data in 8bit pixel format
        bus6bit(lcdbyte)
    '    LCD_WR_Low
    '    LCD_WR_High
        LCD_WR_CS_High
    '' DISPLAY SETTINGS
    PUB Address_set(x1,y1,x2,y2)
        Lcd_Write_Com($002B)
        Lcd_Write_Data((x1>>8)&$00FF)
        Lcd_Write_Data(x1&$00FF)
        Lcd_Write_Data((x2>>8)&$00FF)
        Lcd_Write_Data(x2&$00FF)
         Lcd_Write_Com($002A)
        Lcd_Write_Data((y1>>8)&$00FF)
        Lcd_Write_Data(y1&$00FF)
        Lcd_Write_Data((y2>>8)&$00FF)
        Lcd_Write_Data(y2&$00FF)
        Lcd_Write_Com($002C)
         LCD_RS_High
    DAT
       VDP        long  271
       HDP        long  479
       HT         long  531
       HPS        long  43
       LPS        long  8
       VT         long  288
       VPS        long  12
       FPS        long  4
       HPW        long  10
       VPW        long  10
    PUB INNI_SSD1963
        LCD_Reset_High
        pause1ms(5)
        LCD_Reset_Low
        pause1ms(5)
        LCD_Reset_High
        LCD_CS_High
        LCD_WR_High
        pause1ms(5)
        LCD_CS_Low
        pause1ms(1)
        pause1ms(5)
        pause1ms(5)
        Lcd_Write_Data($0001)                             ' //GPIO[3:0] out 1 GPIO 0= High
        Lcd_Write_Data($0009)                             ' //GPIO3=input, GPIO[2:0]=output
        Lcd_Write_Data($0000)                              ' 3 is 180
        Lcd_Write_Data($0000)                             ' 000 = 8-bit , 001 = 12bit ,010=16-bit,011=16-bit(565)
        pause1ms(5)
       ' Lcd_Write_Com($002c)
        Lcd_Write_Com ($003A)                              ' //Set Pixel format
        Lcd_Write_Data($0020)                              ' A[6:4] 010=8bit(HEX=20)    101=16bit(HEX=50)
       ' Lcd_Write_Com ($0038)
        'Lcd_Write_Data($0001)
           pause1ms(50)
    PUB LCD_Pixel(RR,GG,BB)| i,j
      repeat 100*101                  'Draw full screen of pixels
            LCD_write_Colorbus(RR)
            LCD_write_Colorbus(GG)
            LCD_write_Colorbus(BB)
    PUB Full_Screen_Fill
       Address_set(0,0,281,479)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
         repeat 134599                  'Draw full screen of pixels
            LCD_write_Colorbus($00)
    PUB Fill_screen_Squares
        Address_set(0,0,100,100)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($00,$00,$00) 'Black
        Address_set(0,101,100,201)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($FF,$00,$00)
        Address_set(0,202,100,302)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($00,$FF,$00)
        Address_set(0,303,100,403)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($00,$00,$FF)
        Address_set(0,404,100,479)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($33,$33,$33)
        Address_set(100,0,200,100)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($CC,$CC,$00)
        Address_set(100,101,200,201)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($00,$33,$00)
        Address_set(100,202,200,302)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($FF,$FF,$FF)
        Address_set(100,303,200,403)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($66,$00,$33)
         Address_set(100,404,200,479)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($00,$00,$CC)
        Address_set(200,0,279,100)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        Address_set(200,101,279,201)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($33,$CC,$CC)
        Address_set(200,202,279,302)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($FF,$00,$FF)
        Address_set(200,303,279,403)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($00,$66,$00)
         Address_set(200,404,279,479)              ' top-pixelline  , left-pixelline,bottom-pixelline, right-pixelline
        LCD_Pixel($66,$99,$00)
    edited 2013-04-22 21:23
    Okay, first off... Here's one of the things that I've spent a lot of time on. It's a weird glitch BUT, toggling /CS and /WR at the SAME TIME really seems to work the best. In the CPLD gating I have these driven from a common clock OR gated with "display enable" latch bit. I've chased a glitch like VID2 down many times and it seemed to have something to do with this. Toggling both pins together has always made this go away.
    I really recommend using the new memory chip. You would still need the '245s, but might be able to simplify the rest of the gating.
    The CPLD design will need a 1.8v rail. Not sure if this is a deal breaker for you. I will have JTAG programmer in the morning so verifying design soon. Then I can share what I've learned.
    For my purposes, P18 = disp/WR ---> OR dispENbit *latch ---> disp/CS.
    Thinking about using P19 for /RS.
    P20 will only be used as clock for Group1-Load.
    Count-enable in Group2, /RAM-CS...
    Group2, Group4 are latchbits? 1,3,5,6,7,8,9, dispRESET are from 138...
    I may absorb more function control into the CPLD, just want to get it working before I start introducing more unknowns. Here's an early iteration:
    The board should look something like this :
    Cost is about the same, way smaller board. External power-supply.
    I think the 8-bit interface would benefit from the CPLD and memory chip as well. Some things to think about!
    728 x 621 - 118K
    830 x 588 - 339K
    edited 2013-04-23 03:32
    Thanks for the explination Joe .
    Ok the toggeling of both lines may help the issue. I think I have to build the schematic back up to try it out .
    Just not sure what I sould do about the logics ic yet. The Memory I will order one of those to keep the parts the same *** you , Verry handy :p
    1.8V not a that big of a deal ,
    Mind giving me a part number on the CPLD. Ill try ordering them , and reading the data to cath up
    what kind of code does the CPLD run on, any develpment software that are needed for it , or will simple ide do the job ?
    It does make for a pretty slick design indeed . Looking forward to seeing that work
  • pilot0315pilot0315 Posts: 954
    edited 2015-03-09 07:06
    I am also having problems initializing the ssd 1963 with a 7 inch tft.
  • RaymanRayman Posts: 15,899
    edited 2015-03-09 09:12
    I've got drivers for SSD1963 with 4.3" 5" LCDs here:
    http://www.rayslogic.com/Propeller/Products/DviGraphics/DVI.htm
    Maybe you could modify the settings to use a 7" display....
    have downloaded your code. I get only lines but it does show that the device works. stripping out code to get to the basics. also trying to port newhaven c code for an arduino to spin for basics. will post both later. thanks
