keypad reader doesnt work :[
i am trying to run the 4x4 keypad demo but i cannot get it to work. i have the keypad hooked up correctly but all i get from the serial terminal is
this is the code for the demo
00000
0000
0000
0000
0000
0000000000000000
{{ 4x4 Keypad Reader PST.spin
Returns the entire 4x4 keypad matrix into a single WORD variable indicating which buttons are pressed. }}
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
text : "Parallax Serial Terminal"
KP : "4x4 Keypad Reader"
VAR
word keypad
PUB start
' Start PST
text.start(115200)
text.str(string(13,"4x4 Keypad Demo..."))
text.position(1, 7)
text.str(string(13,"RAW keypad value 'word'"))
text.position(1, 13)
text.str(string(13,"Note: Try pressing multiple keys"))
repeat
keypad := KP.ReadKeyPad '<-- One line command to read the 4x4 keypad
text.position(5, 2)
text.bin(keypad>>0, 4) 'Display 1st ROW
text.position(5, 3)
text.bin(keypad>>4, 4) 'Display 2nd ROW
text.position(5, 4)
text.bin(keypad>>8, 4) 'Display 3rd ROW
text.position(5, 5)
text.bin(keypad>>12, 4) 'Display 4th ROW
text.position(5, 9)
text.bin(keypad, 16) 'Display RAW keypad value
You could also use resistors as Larry suggests but I'm not sure if you can use the same object.
