calculator input?!
im trying to use a matrix keypad for user input for a calculator using a basic stamp 2 micro controller. I am having issues getting my code to store the button pressed and then putting them all together. So lets say someone wanted to enter the number 25. the program has to store the 2 and the 5 as variables and then multiply the 2 by 10 and add 5. pretty strait forward but looping this is difficult since the keypad outputs what seems to be zero when nothing is pressed. so my variables just become zeros >____< I only need to get a max 3 digits since this is going to be used for an 8 bit calculator...
I believe I just have to use some if then statements and some do loop statements... anyone have any ideas? ive googled this too but to no avail.
this is what im trying to use but it keeps going to the gosub compile.... without a or b being pressed..... :[
' {$STAMP BS2} ' {$PBASIC 2.5} row VAR Nib ' Variable space for row counting column VAR Nib ' Variable space for column counting keypad VAR Word ' Variable space to store keypad output keypadOld VAR Word ' Variable space to store old keypad output temp VAR Nib ' Variable space for polling column states keynum VAR Word ' Variable for keystroke placeholder VAR Nib ' Variable for keeping track of digit placement ks1 VAR Nib ' variable for 1st keystroke ks2 VAR Nib ' variable for 2nd keystroke ks3 VAR Nib ' variable for 3rd keystroke finalnum VAR Nib ' variable for final number output placeholder = 0 DO GOSUB readkeypad GOSUB display IF keypad <> keypadold THEN GOSUB placedigit ENDIF IF keynum = "A" OR "B" THEN GOSUB compile ENDIF LOOP ' -----[ Subroutine - compile ]------------------------------------------------- compile: IF placeholder = 0 THEN finalnum = ks1 IF placeholder = 1 THEN finalnum = ks1 * 10 + ks2 IF placeholder = 2 THEN finalnum = ks1 * 100 + ks2 * 10 + ks3 DEBUG DEC ? finalnum, CR DEBUG BIN ? finalnum, CR RETURN ' -----[ Subroutine - Placedigit ]------------------------------------------------- placedigit: IF placeholder = 2 THEN ks3 = keynum IF placeholder = 1 THEN ks2 = keynum placeholder = 2 ENDIF IF placeholder = 0 THEN ks1 = keynum placeholder = 1 ENDIF RETURN ' -----[ Subroutine - ReadKeypad ]------------------------------------------------- ' Read keypad button states readkeypad: keypad = 0 OUTL = 000000 ' Initialize IO DIRL = 000000 FOR row = 0 TO 3 DIRB = 11 ' Set columns (P7-P4) as outputs OUTB = 00 ' Pull columns low (act as pull down) OUTA = 1 << Row ' Set rows high one by one DIRA = 1 << Row temp = 0 ' Reset temp variable to 0 FOR column = 0 TO 3 INPUT (column + 4) ' Set columns as inputs one by one temp = temp | (INB & (1 << column)) ' Poll column state and store in temp NEXT keypad = keypad << 4 | (Temp REV 4) ' Store keypad value NEXT RETURN ' -----[ Subroutine - Display ]---------------------------------------------------- ' sets numbers display: IF Keypad.bit15 THEN keynum = 1 IF Keypad.BIT14 THEN keynum = 2 IF Keypad.BIT13 THEN keynum = 3 IF Keypad.BIT12 THEN keynum = "A" IF Keypad.BIT11 THEN keynum = 4 IF Keypad.BIT10 THEN keynum = 5 IF Keypad.BIT9 THEN keynum = 6 IF Keypad.BIT8 THEN keynum = "B" IF Keypad.Bit7 THEN keynum = 7 IF Keypad.Bit6 THEN keynum = 8 IF Keypad.Bit5 THEN keynum = 9 IF Keypad.Bit4 THEN keynum = "C" IF Keypad.Bit3 THEN keynum = "*" IF Keypad.Bit2 THEN keynum = 0 IF Keypad.BIT1 THEN keynum = "#" IF Keypad.Bit0 THEN keynum = "D" RETURN
accumulator = accumulator * 10 + keynum
keynum is a value from 0 to 9 representing the numeric key just pressed.
If you want a backspace or remove digit command key, you'd do:
accumulator = accumulator / 10
In your "display" routine, what's the value of keynum if Keypad is all zero bits.
In your "display" routine, what's the value of keynum if Keypad is all zero bits?
IMO, writing a calculator program is a great coding exercise. I thoroughly enjoyed programming a simple talking calculator using a computer keyboard and integer math on "another processor": http://www.youtube.com/watch?v=624cmIr5qBs&feature=player_detailpage#t=28s
Later, I found this nifty talking calculator on Ebay for $9 and just had to have it: http://www.ebay.com/itm/250976474687
wow i knew there was an easier way to do it! i have much better code now but i am having an issue with that its doing the accumulator thing twice....
here is the code i am now using
and the debug terminal gives me
i put that pause in attempt to debounce it but that obviously isnt working. why is keypadold not equal to keypad? that must be the issue since it is doing it twice... but why does it stop after just doing it one extra time? no idea......
edit:
thank you so much sapphire that worked great!
and thanks again mike green for getting me started in the right direction!
