Light and color sensor response time
Hello everybody!
We are interested in color detecting device, that can detect color of an irregular object, app. 2mm x 2mm x 2mm small at travel speed around 0.3m/s, then send signal to any controller. Minimum response time as I understand is around 1-3ms.
Also inspected sensor covered area must be as small as possible. I afraid that if covered area is big, result will be average color of base and color object, that will give wrong result.
Please give these properties for sensors:
TCS3200-DB Color Sensor and ColorPAL also.
Look at the ColorPAL documentation for information on field of view and speed. The ColorPAL's field of view is determined mostly by the tube that holds the LED and sensor. There's no lens other than those that are part of the LED and sensor. The ColorPAL uses asynchronous serial I/O up to 7200 Baud and requires several characters normally to make a measurement. That would take well over 3ms. Look at the documentation for details.
