Gel Cell Charger Deals
Lead acid ain't sexy. Not high-tech. Low power to weight. But... pretty safe (they don't explode like some Lithium batteries have), cheap and plentiful. Used in many alarm systems, and some robots. We've all got 'em, I've used 'em. Even as I transition to lithium, my numerous old gel cells are useful for testing and more. Here are some cheap chargers I've seen (and ordered) lately:
12V/$4 http://www.goldmine-elec-products.com/prodinfo.asp?number=G19029 "smart" charger uses an external relay to disconnect power cube when fully charged sale ends April 16
12V/$5.51 free ship http://www.ebay.com/itm/181060264290 appears to be a float charger, based on description at http://www.aliexpress.com/item/12V-Volt-Rechargeable-Sealed-Lead-Acid-Battery-Charger-free-shipping/624988081.html
6V/$5.51 free ship http://www.ebay.com/itm/181062310876 better description at http://www.aliexpress.com/item/6V-6-Volt-Sealed-Lead-Acid-Rechargeable-Battery-Charger/545730265.html
Here's a good deal on a new 6V, 4.5Ah battery w/free ship for $9.10. Lead acids are heavy, often garnering high shipping prices. http://www.ebay.com/itm/6V-4-5AH-Sealed-Lead-Acid-SLA-Battery-for-Home-Alarm-Security-Systems-/140944681270?ssPageName=ADME:X:RTQ:US:1123
That seller has lots of other battery deals, worth a peek.
I started out with 6 volt and 12 volt gel cells and related chargers, but kept finding the 6 volt cells were a bit too low for voltage regulators and the 12 volt cells were a bit too high.
Then I discovered I could locally buy 8 volt gel cells with 9AH rating and I could simply trickle charge them with a 500ma 9 volt DC wall wart. Life had never been the same.
tonight If Iam not dead from my cold . Illl pop open a 7 AH 12V AGM and show yall then insides .
the issue here is not in a name but how Real GCs have far different charging requirements then a Flooded and a AGM ..... the latter 2 have far more in common ...
http://bdchargers.com/batterytypes.php
90 % of the black case small batts you buy are AGMs now ......
the seller on the 6V 4.5 AH states its a AGM .....
* Absorbed Glass Mat (AGM)
* Maintenance Free battery
* Non Spilled
* High Performance
* Best Battery Life
* Safety in all Positions
Peter...
I wonder if those would work for a Hero 1 ?
Kenny
Sure should. Hero 1 used 4x 6V batteries, IIRC.
Another option is to use a 12V 7Ah battery (same battery volume) and wire in a zener diode to provide 6V for the logic, per http://hero.dsavage.net/robots/Hero_FAQ.html#2.5.1
So naturally I just ordered a 6V charger too.
Thanks for that link, thats what I needed to know.
But what is the problem with AGM? From the article they appear to be the best general choice?
Not in terms of expenses.. they are more costly.
I wouldn't recommend that option. You can easily user a 12V 7AH for the motor drive and just keep a pair of 6V batteries for the logic. That is a nice upgrade since it gives more capacity for the motors. If you have to use a 12V battery for the logic then a better option would be one of the small 3-pin 6V switching regulators.
If you are charging the batteries directly then make sure the robot is switched off and the original charger is unplugged.
Attachment not found.
most of the smaller then 50 AH batts you see are AGMs ,/ No one cares about super duper deep cycle life In stuff We make here ...
ll bet the most common Pba batt we use is the 7 AH 12V class . Perhaps the 5AH class too . this is a Very small batt as far as the batt world goes ...
Most Gels START at 30 AH ,,,, your medusa or home bot is not gonna use a 30 AH batt.....
What you see on the shelf at rad shack and what you have in the spiral cell car batt and in in most every UPS is a AGM batt .
Only people I know that willfully use a True GEL is in power chairs... ( 33AH or so class )
and in some Low draw telecom backups .
