AP16+ issues
I purchased this item from Parallax as it has many appealing features. The documentation is clear but has holes. For example, there is no pin-out documentation on the serial connector. The sample code references only one IO to the AP16+ so I assume the W pin is serial, R is +5 and B is gnd. However, when I run the sample code it doesn't work. I know my sample audio works because I made an exact copy and called it AMBIENT.WAV and it worked when I set switch 6 to ON. It plays beautifully.
Any help? Are there more detailed documentation of the board? Is there any details on the jumper?
many thanks,
Al
many thanks,
Al
Does anything work with the test program? If some parts work, which are they? What happens with the other parts?
Is it normal that the relay engages every time the sound is played or is it some setting/jumper that needs to be changed? Again, documentation is not very clear. I am spoiled with Parallax's perfect documentations.
Al
