USB Error — Parallax Forums
USB Error
zorasterzoraster Posts: 10
edited 2013-04-14 04:37 in Propeller 1
I have purchased a quick start board but the propeller tool says that every usb port is com6. I also have a propeller board of education and when it is hooked up the propeller tool identifies each port differently. Does anyone know of a fix or work-around for this?
John Wonch
  • RaymanRayman Posts: 16,035
    Can you exlain the problem a bit more? Sounds like normal behavior to me...
    Windows gives every FTDI USB chip it finds a new com port#.
    So, different Parallax boards will get different com numbers.
    That com# may stay the same if you move the same board to another USB port.
