Simple - no response — Parallax Forums
Kirk FraserKirk Fraser Posts: 364
edited 2013-04-12 22:44 in Propeller 1
It has to be a simple problem I'm overlooking. F10 or F11 loads this code to my Prop with no errors but it won't show anything on serial terminal. The terminal is set to Com3 57600 and fails even after F11, hit Enable, then the Prop reset switch to give it the best chance of working. Thanks.
OBJ
  STrm : "Parallax Serial Terminal"         'Access SerTerm Object
con
  _clkmode = xtal1 + pll16x
  _xinfreq = 6_000_000                                          ' use 6MHz crystal
  CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq
PUB ComTest   |  x
  STrm.Start (57600)             'Initialize timing, Rx and Tx pins for DEBUG
  repeat
    x := 26
    STrm.Str(string(13,"Test dec: "))
    STrm.Dec(x)
    STrm.LineFeed
    STrm.Str(string(13,"Test hex: "))
    STrm.hex(x,1)
    STrm.LineFeed
    STrm.Str(string(13,"Test bin: "))
    STrm.bin(x,12)
    STrm.LineFeed
    STrm.Str(string(10))
    waitcnt(clkfreq + cnt)
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-04-12 15:57
    F11 or F12? F12 should bring up Serial Terminal.
    edited 2013-04-12 16:12
    I'm presuming by the code above you have a 6mhz xtal fitted not 5?
  • Kirk FraserKirk Fraser Posts: 364
    edited 2013-04-12 16:24
    skylight wrote: »
    Yes, it takes a magnifying glass to read it but it's a 6.000
    edited 2013-04-12 17:00
    Is this a standard Parallax board? Should be 5.0 Mhz. 6.25 Mhz is another optional xtal that Parallax sells. I don't believe they sell a 6.0 Mhz.
    Is your Propeller chip actually on COM3:? You may have another choice in PST.
    edited 2013-04-12 17:13
    Publison wrote: »
    No it's a custom board with a Digi Key crystal. F7 says it's on COM3.
    edited 2013-04-12 17:21
    This code runs fine on a PPDB with 5. Mhz xtal
    OBJ  STrm : "Parallax Serial Terminal"         'Access SerTerm Object
    con
      _xinfreq = 5_000_000                                          ' use 6MHz crystal
     ' CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq
    PUB ComTest   |  x
      repeat
        x := 26
        STrm.Str(string(13, "Test dec: "))
        STrm.Dec(x)
        STrm.LineFeed
        STrm.hex(x,1)
        STrm.LineFeed
        STrm.bin(x,12)
        STrm.LineFeed
    Do you have a part number for the crystal?
    edited 2013-04-12 17:40
    Interesting, thanks for testing.
    The part number on the part is TXC 6.000c8H
    This part is no longer found at DigiKey or on Google. So maybe I need to buy another one. I don't understand why it will program with it but not run.
    edited 2013-04-12 18:06
    Almost looks like a part number for a Temperature compensated crystal oscillators (TCXO) which might have different capacitive characteristics.
    Check out page 68 of the Propeller Manual Ver. 1.2. If it's an external Oscillator, you may want to try XINPUT instead of XTAL1.
    Worth a try. Got a picture of it?
    edited 2013-04-12 18:11
    When you program the Prop it's using it's internal clock instead of the external crystal, so that would explain it working for programming but not running, if it is indeed a crystal problem.
  • ChrisGaddChrisGadd Posts: 310
    edited 2013-04-12 18:25
    Is the Propeller showing any signs of life at all? My very first fried Prop gave every indication of being programmed, but produced absolutely no output at all. Completely comatose, from getting my 5V and 3.3V supplies crossed.
    edited 2013-04-12 18:50
    Thanks guys, I think that gives me enough to try for now.
    The part number is likely TXCo6.000c8H but I didn't put in the small o as it looks like a square. The part looks just like a Parallax crystal.
    Thanks for the ideas on how programming can work but not run.
    I am sure my 3.3V is ok but I've moved since I did much work on the PCB so I have misplaced lots like spare LED's. So I'll try the program change then buy some LED's to see if the Prop works.
    edited 2013-04-12 19:20
    Try a simple program that toggles a pin using the internal clock to see if it dead or alive.
    Confirmed, the Prop chip was dead. Thanks everyone!
