Prop2 versus Prop1 LMM speed — Parallax Forums
RaymanRayman Posts: 16,036
edited 2013-04-13 08:26 in Propeller 1
Is it too early to tell the speed increase going to P2 from P1?
I'm just playing around, but I think I see ~4X increase per clock, consistent with single clock instructions on P2 and 4 clock instructions on P1.
Do the new instructions give any speed increase?
    edited 2013-04-12 06:45
    Rayman wrote: »
    Certainly rdlongc helps a lot since it only hits the hub one out of every four instructions. This is even better in CMM mode. Right now we're working on a relatively straight-forward port of the P1 compiler to P2. There may be other advantages to be gained from the new P2 features (like the CLUT) but they are likely to require significant compiler backend work and we don't have the time or resources to tackle that on the first pass.
  • RaymanRayman Posts: 16,036
    edited 2013-04-12 07:27
    Thanks. That's kinda what I figured. Sounds like it may get faster in the future then.
  • KyeKye Posts: 2,200
    edited 2013-04-13 07:49
    Should be able to hit above 160 MHz on the real chip. So, roughly a 10 X increase from the prop 1.
  • jazzedjazzed Posts: 11,803
    Kye wrote: »
    I seriously doubt that existing tools, except possibly SPIN, will ever achieve 10X performance increase without significant rewrite.
