reading counter A (phsa value) from a different cog — Parallax Forums
courtenscourtens Posts: 101
edited 2013-04-09 21:47 in Propeller 1
Is is possible to read the A or B counter from a different cog, or can this only happen within the same cog?
    edited 2013-04-09 21:39
    courtens wrote: »
    No, cog registers are private. The closest you can get to it is when the cog owning the counters periodically transfers their values to hub.
  • courtenscourtens Posts: 101
    Thank you ... I will have to code around it.
