Prop BOE and Express PCB
Does anyone have a schematic/PCB layout of the Prop BOE, preferably in Express PCB format? I am working on my project for the Micro Medic contest and it sure would be nice to have a premade Express PCB schematic as that would save me (and I am sure others) a ton of time when the project gets to that stage. I am a bit backwards. I usually build and then put it on paper!!!!
Would any of this help as a starting point instead?
http://www.rayslogic.com/propeller/PropPCB/PCB_Boards.htm
Maybe this?
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/32900_PropBOE_RevA_Schematic.pdf
Here's another page maybe to have a look at. There's an expressPCB file on it that might help.
http://www.parallax.com/tabid/808/Default.aspx
(Hey, if nothing else, I'll just keep bumping up your post until somebody with the file you want will see it.)
Drat. Well, in any case, it looks like they're the same files as was posted on Rayslogic.com, anyway. Bumpitity bump bump....
I'm pretty sure Express PCB is an expensive way of having a circuit board made. There are lots of other less expensive options.
Many of Parallax's boards have DipTrace files available. IMO, DipTrace is much easier to use than Eagle. It didn't take me long to advance beyond what I could do in Eagle once I started to learn to use DipTrace (not that I ever got very good at Eagle, I thought it was frustrating to use).
You might have a problem accessing the PropBOE's DipTrace files (if they're available) since the free version of DipTrace is limited to two signal layers.
