Any soldering iron tip friendly CPLDs available? — Parallax Forums
CuriousOneCuriousOne Posts: 931
edited 2013-04-10 23:15 in General Discussion
Hello. For some tasks, I need to integrate several logic elements into one compact case. Lattice has nice solutions, but simple ones are all BGA or DFN. The complex ones are TQFP or other, more solderable packages, but they are way too large both in terms of features and price. All I want is say 10 NOR, 10 NAND gates in one case, but in compact package with legs protrunding at sides, say SOT-23 or SOIC-8. Are they available?
  • LeonLeon Posts: 7,620
    edited 2013-04-09 04:36
    You won't find anything like that.
    The smallest Altera CPLD is the EPM7032B, available in PLCC44 and TQFP44.
    edited 2013-04-09 08:50
    Bad, will have to do it via MCU...
  • jmgjmg Posts: 15,194
    edited 2013-04-09 16:14
    CuriousOne wrote: »
    I'm not sure what you mean by 10 NOR and SO-8, as they seem mutually exclusive, but if you want small PLDs, then look at
    ATF16V8BQL / ATF16V8CZ / ATF22V10 / ATF22LV10 / ATF750
    Available in PLCC20/24 TSOP20/24 and SO20W/24W - and DIP as well.
    and there is also this, not quite as easy to solder, but it is very small
    SLG46400 Programmable Mixed Signal Array 1.8V - 5.5V TDFN-12
    http://www.silego.com/products/greenpak2.html
    edited 2013-04-09 16:43
    Jmg I have been looking at these lately, I was wondering if you could help me understand the difference in something like a plain old 22v10 from atmel, and the ATF750? Obviously the 750 is a faster chip with more logic, but does it require special tools over a standard 22v10 chip? I am very intrested in this technology I believe some people call it "GALS" which I think is actually a lattice coined term? I also understand that the 22v10 can be programmed via a standard universal programmer, but those seem a bit pricey... Do you know how one could get in to 22v10's with free software and a DIY programmer?
    @CuriousOne
    http://www.seeedstudio.com/depot/index.php?main_page=advanced_search_result&search_in_description=0&keyword=cpld&x=26&y=11 These are fairly cheap, you can find cool runner boards on ebay for even less but as far as I can tell they do not break out all the pins! The cool runner can be programmed with a bus pirate or a diy solution via parallel/serial cable I believe and of course using xilinx cables. I would recommend a bus pirate, on top of the awesome debugging and testing capabilities they have for the hobbyist, they can program AVR's PICs and CPLDs, even more once you buy one, you can then sample the pic from microchip in DIP format and build your own bus pirates using the one you bought as a PCI programmer. In reality though, if you are just looking for a DIP style programmable logic chip, I would stick with the list jmg provided, and research GAL circuits on google. As you can tell getting started with them is a bit confusing.
    edited 2013-04-09 17:31
    The Software flow is the same, just change Device to ATF750C, and compile in CUPL.
    The ATF750 is roughly 2 x 22V10, with one x10 buried, and one x10 brought to pins.
    It also has .T/,D ff, and more clock choices.
    You do need a programmer that understands the ATF750C, and that is more of an issue than the tools.
    Plenty ~ $100 support the 22V10, but the ATF750 is less common, and bumps the programmer price.
    At that stage, you could look at the ATF1502ASL - cheaper than the ATF750CL, and JTAG ISP.
    The ATFxx series SPLDs use a high voltage ( 12V region) Vpp, and there are more pins need wiggling than SPI, and I think some signatures need reading, to select pulse widths, but there is nothing a small uC could not manage.
    The HW gets more complex, if you want to include Vector Testing, which is a good idea.
    So you can see why universal programmers tend to be required.
    edited 2013-04-09 20:19
    DIP-8 is way too big for me. On the other hand, DFN and all other cases which have pins under the IC case, also aren't good for me.
    20 NOR gates can go well in SOIC-8. Say I need to have output signal only when pulses on all 5 inputs arrived in specific order. All gates will be used, while having 5 inputs and 1 output.
    edited 2013-04-09 21:38
    CuriousOne wrote: »
    DIP-8 is way too big for me. On the other hand, DFN and all other cases which have pins under the IC case, also aren't good for me..
    You can make DFN easier, if you extend the fingers on a default footprint. Not as nice as gull wing, but tolerable.
    CuriousOne wrote: »
    PLDs can do state-engines easily, but they do need a clock for that.
    They deploy best in areas where uC simply are not fast enough, or lack a feature.
    eg a 16V8 can be used to add quadrature counting in HW, to a Prop, which has No QuadIn, and Up only counting.
    The PLD takes the QuadIn, and outputs two clocks, which drive two counters. CW increments one counter, and CCW increments the other
    The difference is your location.
    If your logic is slow enough to poll, then a small uC can be better.
    Something like the Z51F0410HCX comes in a SSOP10 (SO8 size, 1mm pitch) and is $1.07 100+, and costs $29.95 to kick off.
    You get wide supply, of 1.8-5.5V, 12b ADC, EEPROM, Osc, and In circuit debug.
    It's hard to find a 12bADC for $1.07, so the small micro is almost free....
    edited 2013-04-10 21:38
    I don't need any fantastic speed or complexity. here's the logic circuit I want to have in 1 IC.
    618 x 389 - 37K
    Choices would be
    a) 20 pin SPLD like ATF16V8BQL, where you would use 5 of the 8 macrocells. (each eqn latch point is a macrocell)
    PLD code in Boolean Equation entry, is written almost as drawn. Uses 62.5% of SPLD macrocells.
    /* CUPL  PLD Boolean Equation Entry  : CUPL / PLD  # = OR and & = AND and ! = NOT */
     PIN     1       =     IP1;  mapping needed
    N1 = !(Reset # N2);
    N2 = !(IP1 # N1);
    N3 = !(Reset # N4);
    N4 = !(N3 # (IP2 & N1));
     Nout = N1 & N3;
    /*  Needs 3 IP pins, and  4+1 = 5 macrocells, will fit in a 16V8BQL */
    b) In a small uC like Z51F0411, (10 pins) this has a some Boolean opcodes, so you can again code almost as written.
    Loop time would be under 2us in a typical core. Uses < 1% of Chip resource.
    ; 8051 ASM
    Rst  EQU P1.0   ; Map IO to pins
    Ip1  EQU P1.1
    Ip2  EQU P1.2
    Nout EQU P1.3
            bseg  at 00   ; Map latch nodes to buried pins, or Boolean memory.
    N1:     dbit    1
    N2:     dbit    1
    N3:     dbit    1
    N4:     dbit    1
            cseg at 0000h           ;Reset vector
    Loop:
    ; N1
            MOV     C,N2
            ORL     C,Rst
            CPL     C
            MOV     N1,C
    ; N2
            MOV     C,N4
            ORL     C,Ip1
            CPL     C
            MOV     N3,C
    ;N4;N3
            MOV     C,N4
            ORL     C,Rst
            CPL     C
            MOV     N3,C
    ;N4
            MOV     C,IP2
            ANL     C,N1
            ORL     C,N3
            CPL     C
            MOV     N4,C
    ;OP
            MOV     C,N1
            ANL     C,N3
            MOV     Nout,C
            SJMP    Loop
                    end
     ;  Code Memory    :    38 bytes = 0.92% used,   Bit memory 4/128,  Data Memory : none,  SFR : none
    and to complete the Boolean logic language examples, here is Pascal version.
    // 8051 Pascal/Modula-2
    VAR
     Rst  : BOOLEAN absolute P1.0;
     Ip1  : BOOLEAN absolute P1.1;
     Ip2  : BOOLEAN absolute P1.2;
     Nout : BOOLEAN absolute P1.3;
     N1, N2, N3, N4 : BOOLEAN;  // use 1 bit of memory, total is half a byte
    BEGIN
      REPEAT
        N1 := NOT (Rst OR N2);
        N2 := NOT (Ip1 OR N1);
        N3 := NOT (Rst OR N4);
        N4 := NOT (N3 OR (Ip2 AND N1));
        Nout := N1 AND N3;
      UNTIL FALSE;
    END.
    The compiler may not be quite as compact as the ASM above, but it is close, and easier to maintain.
