NCO Counter Issue — Parallax Forums
NCO Counter Issue
Jack ScarletJack Scarlet Posts: 15
edited 2013-04-12 23:04 in Propeller 1
Hello,
I'm fairly new to Propeller programming and have been playing around with counters.
I'm using the following code to generate 46875 hz output and a 12mhz output.
CON
_clkmode = xtal1 + pll16x ' clkfreq = 80 MHz.
_xinfreq = 5_000_000
PUB CounterTest
frqa := 2_516_582 ' FRQA = 46875 * (2^32 / clkfreq)
ctra[30..26] := %00100 ' Set ctra for "NCO single-ended"
ctra[5..0] := 2 ' Set APIN to P2
dira[2]~~ ' Set direction of PIN
frqb := 322_122_547 ' FRQB = 12_000_000 * (2^32 / clkfreq)
ctrb[30..26] := %00010 ' Set ctra for "PLL single-ended"
ctrb[25..23] := 4 ' Set PLLDIV to 4x
ctrb[5..0] := 3 ' Set APIN to P3
dira[3]~~ ' Set direction of PIN
repeat
The problem is when I look at the outputs using my Saleae Logic every so often I see values of
469667 and 467836 hz grouped together.
Is it not posible to generate a stable 46875 hz output using an NCO mode counter, am I doing something wrong, could it be my logic Analyzer or are discrepancies like these normal ?
Cheers
Jack :)
  • KyeKye Posts: 2,200
    edited 2013-04-08 06:10
    Hi, you need to use the PLL with the NCO mode. NCO produces jitter. The PLL will clean that up for you.
    Basically, in the PLL mode, you generate the same NCO output, but, then that goes into the PLL which locks onto the average target frequency and is quite stable. I'm not sure you can hit below, however, 500,000 Hz with the PLL mode.
  • Jack ScarletJack Scarlet Posts: 15
    edited 2013-04-08 06:21
    Thanks Kye, I'll have to do some more reading :)
  • jmgjmg Posts: 15,194
    edited 2013-04-08 16:12
    Is it not possible to generate a stable 46875 hz output using an NCO mode counter, am I doing something wrong, could it be my logic Analyzer or are discrepancies like these normal ?
    You should expect some deviation, but not quite that much - what is the sample time of the Logic analyser ?
    A logic analyser will introduce additional sampling errors, on top of the 12.5ns quanta the NCO works in.
    Assuming those quoted values simply missed a decimal point, we have
    80e6/46966.7 = 1703.33449018134125
    80e6/46783.6 = 1710.00094050051728
    So the average is close, but the spread is larger
    A good way to check the stability and jitter nature of the NCO, is to get an expanded/egyptian fraction form
    The requested 46875 maps to
    80e6/46875 = 1706.66666666666667
    ie you divide on average, by 1706 2/3
    This is a simple example, but we flip to the Time-domain, to get
    Target period is
    1/46875 = 2.13333333333333333e-5 ( 1706.66666666666667/80e6 )
    This will be made up of building blocks of the two nearest values of
    1707/80e6 = 2.13375e-5
    1706/80e6 = 2.1325e-5
    and this gives 1 cycle of /1706 and 2 cycles of /1707, repeating every 3 cycles
    (1*(1706/80e6)+2*(1707/80e6))/3 = 2.13333333333333333e-5
    Another way to think of this, is that the edges are snapped to the nearest 12.5ns tine slot.
    How much jitter you measure, depends on your gate time, but I would not expect to see values outside of these limits :
    80e6/1706 = 46893.3177022274326
    80e6/1707 = 46865.8465143526655
    These are the two component frequencies, which are averaged to 46875.000, note they are 'off' by -393ppm and +195ppm
    If you have a gate time of a multiple of 3 cycles, you will measure 46875.0000Hz, but when the gate time does not divide into the fractional expansion, you will see the 12.5ns snap effect.
    taking ~ 100ms, and 4700 cycles, we will measure
    1/((1567*(1706/80e6)+3133*(1707/80e6))/(1567+3133)) = 46875.0019479305996
    1-ans/46875 = -41.55 ppb, error, when taken over 4700 cycles. ( the more cycles the less this error averages to )
    edited 2013-04-08 18:59
    Jmg, thanks for your reply. My analyzer is set at 24mhz sample rate. I think I understand what your saying. So the ideal situation would be to use a crystal and clock frequency that gives an integer result of CLKFREQ / desired output frequency.
    edited 2013-04-08 19:18
    That explains why you see the ~ 6.66 times worse spread numbers that you did. - but it does show the effect of finite samples.
    A 1GHz sample analyzer would show closer to the real prop values.
    If you want no jitter artifacts, yes. you need a adder value that can repeat with no fractions, or you have to manually reload/fix the Counter, which effectively disables the adder (or removes the fractional part).
  • Mark_TMark_T Posts: 1,981
    edited 2013-04-09 13:53
    My bugbear again: "hz" and "mhz" are wrong, the unit is the "hertz" or "Hz", note the case. "MHz" is 10^6 Hz, "mHz" is 10^-3 Hz.
    Most but not all units named after people are lower case when written in full, uppercase for the abbreviated version (volt/V, amp/A,
    hertz/Hz, henry/H, farad/F, kelvin/K). Most units not named after people are fully lower case (candela/cd, barn/b, metre/m, light-year/ly)
    Mark_T wrote: »
    Thanks Mark, good to know! :)
