Understanding RTC communication
Erlend
                    I am working my way through Kwabena's RTC engine. Plan is to mod it to be a reader only, which returns the timedate data packed into one LONG variable - into bits 1-5(sec), 6-10(min), 11-14(hr), 15-17(dow), 18-21(day), 22-25(month), 26-29(year-2000). I want it to contiously poll the time, package it, and write it to the parent cmpTime variable. So, it has to run in it's own cog.
Below is the core of the code. I do not understand what is going on. Confusingly many returns, bolean operations, and bitshifts. Would anyone care to explain me?
Erlend
PUB readTime '' 11 Stack Longs                        'Reads the RTC data and converts to time-data, and puts it into time[]
  return getRam(0)
PRI getRAM(index) ' 8 Stack Longs
  startDataTransfer
  result := transmitPacket(constant(104 << 1))
  result and= transmitPacket(index)
  stopDataTransfer
  startDataTransfer
  result and= transmitPacket(constant((104 << 1) | 1))
  if(index)
    result &= receivePacket(false)
  else
    bytefill(@time, 0, 7)
    if(result)
      repeat 7
        timeTemporary := receivePacket(6 <> index)
        time[index++] := (((timeTemporary >> 4) * 10) + (timeTemporary & $F))
  stopDataTransfer
PRI transmitPacket(value) ' 4 Stack Longs
  value := ((!value) >< 8)
  repeat 8
    dira[dataPin] := value
    dira[clockPin] := false
    dira[clockPin] := true
    value >>= 1
  dira[dataPin] := false
  result := not(ina[dataPin])
  dira[dataPin] := true
PRI receivePacket(aknowledge) ' 4 Stack Longs
  dira[dataPin] := false                            '
  repeat 8
    result <<= 1                                    '
    result |= ina[dataPin]                          '
  dira[dataPin] := (not(not(aknowledge)))
PRI startDataTransfer ' 3 Stack Longs
  outa[dataPin] := false
  outa[clockPin] := false
PRI stopDataTransfer ' 3 Stack Longs
Erlend
The getRam function just gets the bytes of time data from the RTC. You should read the DS1307 RTC data sheet for more information about what that is doing. The constant(104) thing is the RTC address. Its shifted 1 because bit 0 specifies a read when the it is 1 and a write when it is 0.
Just try to get a good grasp on the I2C bus and then read the data sheet for the DS1307 and you'll understand.
repeat 8
dira[clockPin] := true value >>= 1
I do know the whole thing is just about picking one bit at the time and put them together - and vice versa.
Erlend
