Driving a 2KW movie light with a basic stamp
I'm working on my other project, but have a new one in mind.
I helped out on a indie movie 2 years ago. To simulate lighting, one of the crew had to click a bright light, like a 2KW movie light on and off at the switch. It didn't work very well as the light flashed on and off and sound peopel could hear the loud clicking of the manual light switch.
So, now thinking, I'm certain that tere is a device that a basic stamp could control that would turn on and off, and vary power outputs inbetween, the light coming from a high capacity movie light. Besides a lightening effect, others could be programmed in, such as the flicker of a fire, a movie theater projector, etc. I'm certain that there are very expensive movie industry solutions for this. But maybe I could put something usable together with a basic stamp.
I geuss what I'm asking about would be a stamp controlable POT that could handle the 2KW of power (maybe even more if more than one light is involved).
Just asking. (really getting iin to this now.)
Henry
Henry
At 120VAC, a 2KW load takes about 20A, more when turned on cold. A SSR rated for this is not cheap and needs a heatsink as well, possibly a cooling fan too. The combination might cost $50 to $100 in small quantities.
JonnyMac could probably give you some practical suggestions and realistic costs.
Lightning has a distinct look. Just turning a light on and off quickly might not be good enough. There is often an iregular brightning with followup lower brightness flashes as discharges trigger other lesse discharges, etc.
I have seen people talk about using a photo flash unit, and saw that this was tried on a set once, but it don't look right. And sometimes the photo flash is so fast, it isn't always captured, as it may happen entirely between frames.
In one case for a big-budget movie they went through hundreds of old photo style flash bulbs. But the special features commentary, the director stated how difficult it was to find those things. Pyrotechnics might be a posibilite, but I want to avoid that route.
If used for a closeup, maybe several high intensity LED's might be able to be controlled in a pattern.
There was a recent Kickstarter for a very bright LED, one of the example uses mentioned was to simulate lightning. SparkFun mentioned this light a while back.
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1311.R0.TR11.TRC1&_nkw=solid+state+relay+40a&_sacat=0&_from=R40
My Basic Stamp controller box is just about done. Looking forward to test it out once I have access to the resources.
Henry
here are the two links
http://www.ebay.com/itm/5V-Four-4-Channel-Relay-Module-optocoupler-PIC-AVR-DSP-ARM-Arduino-8051-/310574401892?_trksid=p2045573.m2102&_trkparms=aid%3D555001%26algo%3DPW.CURRENT%26ao%3D1%26asc%3D14909%26meid%3D6824055570220810373%26pid%3D100034%26prg%3D1117%26rk%3D2%26sd%3D180946984104%26
and
http://www.ebay.com/itm/Eight-8-Channel-5V-Relay-Module-Expansion-Board-Arduino-PIC-AVR-ARM-MCU-DSP-/330902782576?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D14952%26meid%3D6824065804050335336%26pid%3D100005%26prg%3D1118%26rk%3D4%26sd%3D310574401892%26
The 2 ebay links you posted are mechanical relays which are not capable of the AC loads you specified.
This what happens when I have only intermittent access to the Internet. I thought I saw specifications for both DC and AC voltages and currents. And didn't see that these were mechanical relays rather than solid-state. Again, had only a few minutes to look them over before my Internet access cut off.
THanks for the heads up. Guess this will involve more research that I had first hoped.
Doing this on literally a shoe string budget. (Like most projects I get myself into.)
Henry
You would probably be OK with these then. Just keep in mind that you'll need to insure the relay board is well isolated to protect anyone from the 120VAC which can be dangerous.
