Some way to get a 2x16 lcd to display the same thing and then have it change?
Currently my code looks like
The problem is that the lcd flashes it really fast and the text does not look solid if there is not a pause, and when there is you either have to hold down the switch or press it at the right time, which is not really what I'm going for.
Any help is appreciated! Thanks
' {$STAMP BS2}
' {$PBASIC 2.5}
TxPin CON 1
n9600 CON 84
HIGH TxPin
PAUSE 100
DO
IF IN3 = 1 THEN
SEROUT TxPin, n9600, [12, 17]
SEROUT TxPin, n9600, ["on"]
ELSE
SEROUT TxPin, n9600, ["off"]
ENDIF
PAUSE 500
LOOP
SEROUT TxPin, n9600, [128, "on "] ' Position to row 0 column 0 and write text
