Spin Help Needed
NWCCTV
I will start by saying I am pretty much a newbie when it comes to Spin. I am getting confused because I am use to coding in VB, VC, VC++ and PBasic. I am really getting confused as to how Spin works. I have entered the Micro Medic contest and I do not really have a whole lot of time to teach myself Spin but I am going to try. What I need help with is the attached Demo code for the Pressure Sensor that comes in the Micro Medic kit. This item is a perfect match for a portion of my project but I just need to modify the code. What I need is when pressure is >= xxx then start the Servo on Pin 16. The Servo I am using is a Parallax continuous rotaion servo. The Servo will continue to turn until pressure is no longer >= xxx. Any help is appreciated.
Pressure Sensor and BarGraph DEMO.spin
Program Date: 1/4/2013
Version: 1.0
Description:
This program reads voltage values from the Propeller BOE's ADC and prints the raw value to
the Parallax Serial Terminal program running on your PC. The program also uses a cog to
show a linear representation of the pressure sensed on a 10-segment LED bar graph.
Propeller BOE Wiring Diagram
=== Pressure Sensor Pin Connections ===
+5v
│ MPX5010 │ │
Pin 1 │ │ │ x x x │
AD0 ───┘ │ └─────────┘
GND
=== LED Bar Graph Pin Connections ===
P0 ──────┐
P1 ──────┫
P2 ──────┫
P3 ──────┫
P4 ──────┫
P5 ──────┫
P6 ──────┫
P7 ──────┫
P8 ──────┫
P9 ──────┫
220Ω │
 GND
CON
'let the compiler know which crystal and PLL settings to use
_xinfreq = 5_000_000
_clkmode = xtal1 + pll16x
INPUT = false 'bit pattern is all 0s
OUTPUT = true 'bit pattern is all 1s
PC_BAUD = 115_200 'PC serial terminal's baud rate
ADC_CH0 = 1 << 0
ADC_CH1 = 1 << 1
ADC_CH2 = 1 << 2
ADC_CH3 = 1 << 3
ADC_ALL = ADC_CH0 + ADC_CH1 + ADC_CH2 + ADC_CH3
'LED Bar graph pin definitions
BAR_GRAPH_0 = 0
BAR_GRAPH_1 = 1
BAR_GRAPH_2 = 2
BAR_GRAPH_3 = 3
BAR_GRAPH_4 = 4
BAR_GRAPH_5 = 5
BAR_GRAPH_6 = 6
BAR_GRAPH_7 = 7
BAR_GRAPH_8 = 8
BAR_GRAPH_9 = 9
OBJ
adc : "PropBOE ADC" 'Requires 1 cog
pc : "Parallax Serial Terminal" 'Requires 1 cog
VAR
'Globally accessible variables, shared by all cogs
long pressure
long cogStack[20]
PUB Go | rawReading
'Start other objects
pc.Start(PC_BAUD)
adc.Start(ADC_CH0)
'Launch additional cogs
cognew(RunBarGraph, @cogStack)
repeat
rawReading := adc.In(0) 'Get the reading from channel 0 on the ADC.
pressure := rawReading / 25 'Scale the raw reading to be displayed on the LED bar graph.
'Note that this scaled reading does not correspond with a particular
'unit of pressure such as mmH2O, mmHg, kPa, or PSI. Check the sensor's
'datasheet (MPX5010DP) for the mV/mmH2O conversion value if you want an
'absolute reading in a particular unit of pressure.
'The global variable "pressure" is shared between this cog and the cog
'that is controlling the LED bar graph.
'===== Print to the PC serial terminal =====
pc.Home
pc.Str(string("=== Pressure Sensor Test ==="))
pc.NewLine
pc.NewLine
pc.Str(string("Raw ADC Value: "))
pc.dec(rawReading)
pc.Chars(" ", 5)
pc.NewLine
waitcnt(cnt + clkfreq/20) 'wait for ~1/20th seconds so as not to flood the computer's serial port with data.
PUB RunBarGraph | i
dira[BAR_GRAPH_9..BAR_GRAPH_0] := OUTPUT 'set range of pins to output
'(this works in this case because the pins are consecutive)
repeat
outa[BAR_GRAPH_9..BAR_GRAPH_0] := 1<<pressure - 1 'Continually set the value of the scaled pressure to the LED bar graph pins.
'Do a little bitwise manipulation to make the LEDs look nice.
DAT
Do you have an active circuit that you are attempting to use the pressure controller with?
It would appear to me, that a some point while running the objects called
That a variable called
long pressure
will be available.
This is all still very confusing to me, but Look for something called long pressure and try using that in your main object.
Sorry if I caused you more confusion,
I'm truly hoping that someone else chimes in here.
Also you might want to try this object for servo control - http://obex.parallax.com/objects/445/
if rawReading => 150 servo.Set(14, -200) 'time.Pause(5000) dira[11] := 1 outa[11] := 1 elseif rawReading << 149 dira[11] := 0 outa[11] := 0I just posted it backwards. I already have a Servo Object that is used in the 32 Servo configuration. I have been commenting out the LED function for Pin 11. When I comment out the servo.Set command the LED lights when the pressure goes above 150 and turns off below 149 and it works as it is suppose to. (Also, I know, I have no comments for what everything does. I usually go and do that after I get the code to work.)The Propeller BOE has a built in ADC. If you don't have a BOE you'll need to add an ADC. That's the MPX5010 in the notes section of the code.
For the LED "dira[11] := 1" should be in your init section toward the top, then toggle it with "outa[11] : = 1" and "outa[11] : = 0" (just some housekeeping)
I haven't used the servo object you're using, but have you gotten it to work all by itself, minus the demo code for the pressure sensor?
{{ Pressure Sensor and BarGraph DEMO.spin Program Date: 1/4/2013 Version: 1.0 Description: This program reads voltage values from the Propeller BOE's ADC and prints the raw value to the Parallax Serial Terminal program running on your PC. The program also uses a cog to show a linear representation of the pressure sensed on a 10-segment LED bar graph. Propeller BOE Wiring Diagram === Pressure Sensor Pin Connections === +5v  │ ┌─────────────┐ │ │ │ │ │ MPX5010 │ │ │ │ │ └─┬─┬─┬─┬─┬─┬─┘ │ Pin 1 │ │ │ x x x │ AD0 ───┘ │ └─────────┘  GND === LED Bar Graph Pin Connections === P0 ──────┐ P1 ──────┫ P2 ──────┫ P3 ──────┫ P4 ──────┫ P5 ──────┫ P6 ──────┫ P7 ──────┫ P8 ──────┫ P9 ──────┫ 220Ω │ │  GND }} CON 'let the compiler know which crystal and PLL settings to use _xinfreq = 5_000_000 _clkmode = xtal1 + pll16x INPUT = false 'bit pattern is all 0s OUTPUT = true 'bit pattern is all 1s PC_BAUD = 115_200 'PC serial terminal's baud rate ADC_CH0 = 1 << 0 ADC_CH1 = 1 << 1 ADC_CH2 = 1 << 2 ADC_CH3 = 1 << 3 ADC_ALL = ADC_CH0 + ADC_CH1 + ADC_CH2 + ADC_CH3 'LED Bar graph pin definitions BAR_GRAPH_0 = 0 BAR_GRAPH_1 = 1 BAR_GRAPH_2 = 2 BAR_GRAPH_3 = 3 BAR_GRAPH_4 = 4 BAR_GRAPH_5 = 5 BAR_GRAPH_6 = 6 BAR_GRAPH_7 = 7 BAR_GRAPH_8 = 8 BAR_GRAPH_9 = 9 OBJ adc : "PropBOE ADC" 'Requires 1 cog pc : "Parallax Serial Terminal" 'Requires 1 cog servo : "jm_servo_8x" VAR 'Globally accessible variables, shared by all cogs long pressure long cogStack[20] PUB Go | rawReading 'Start other objects servo.start(1, 14) pc.Start(PC_BAUD) adc.Start(ADC_CH0) 'Launch additional cogs cognew(RunBarGraph, @cogStack) repeat rawReading := adc.In(0) 'Get the reading from channel 0 on the ADC. pressure := rawReading / 25 'Scale the raw reading to be displayed on the LED bar graph. 'Note that this scaled reading does not correspond with a particular 'unit of pressure such as mmH2O, mmHg, kPa, or PSI. Check the sensor's 'datasheet (MPX5010DP) for the mV/mmH2O conversion value if you want an 'absolute reading in a particular unit of pressure. ' 'The global variable "pressure" is shared between this cog and the cog 'that is controlling the LED bar graph. if rawReading => 150 servo.set(14, 200, 2) elseif rawReading < 149 servo.halt(14) '===== Print to the PC serial terminal ===== pc.Home pc.Str(string("=== Pressure Sensor Test ===")) pc.NewLine pc.NewLine pc.Str(string("Raw ADC Value: ")) pc.dec(rawReading) pc.Chars(" ", 5) pc.NewLine waitcnt(cnt + clkfreq/20) 'wait for ~1/20th seconds so as not to flood the computer's serial port with data. PUB RunBarGraph | i dira[BAR_GRAPH_9..BAR_GRAPH_0] := OUTPUT 'set range of pins to output '(this works in this case because the pins are consecutive) repeat outa[BAR_GRAPH_9..BAR_GRAPH_0] := 1<<pressure - 1 'Continually set the value of the scaled pressure to the LED bar graph pins. 'Do a little bitwise manipulation to make the LEDs look nice. DAT {{ ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}Actually you might want to put a small wait after initializing the servo object
The error probably means the correct object isn't specified but I'm not 100% on that.
Also this:
Should be:
oops!
