QTI Navigation
I've got a bot setup with 4 QTI sensors so that it tracks a black line. My objective is to make the bot turn right the first two times when it reaches a T intersection (CASE %1111), keep going forward the next two times, turn right the next four times, keep going forward the two next times, right next four, etc.
I've looked into using a counter variable but I can't seem to get that to work. I understand that I have to implement something for CASE %1111 but I'm rather new to this...help would be appreciated!
Here is my current code:
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' LineFollowWithCheckQtis.bs2
' Navigates based on values acquired with the Check_Qtis subroutine.
qtis VAR Nib ' qti black/white states
OUTB = %1111 ' Set OUTB bits to 1
' Main DO...LOOP
GO
GOSUB Check_Qtis ' Get QTI states
SELECT qtis ' Control servo speeds/directions
CASE %1000 ' Rotate right
PULSOUT 13, 600
PULSOUT 12, 600
CASE %1100 ' Pivot right
PULSOUT 13, 750
PULSOUT 12, 650
CASE %0100 ' Curve right
PULSOUT 13, 800
PULSOUT 12, 650
CASE %0110 ' Straight ahead
PULSOUT 13, 900
PULSOUT 12, 600
CASE %0010 ' Curve left
PULSOUT 13, 900
PULSOUT 12, 700
CASE %0011 ' Pivot left
PULSOUT 13, 900
PULSOUT 12, 750
CASE %0001 ' Rotate left
PULSOUT 13, 900
PULSOUT 12, 900
CASE %1111
PAUSE 100
PULSOUT 13, 900
PULSOUT 12, 600
CASE ELSE ' Do nothing
PAUSE 3
ENDSELECT
LOOP
Check_Qtis:
' Result -> qtis variable. 0 means white surface, 1 means black
' surface.
DIRB = %1111 ' P7..P4 -> output
PAUSE 0 ' Delay = 230 us
DIRB = %0000 ' P7..P4 -> input
' PULSOUT UnusedPin, 0 ' Delays = 208 + (Duration*2) us
qtis = INB ' Store QTI outputs in INB
RETURN
' {$STAMP BS2sx}
' {$PBASIC 2.5}
' Main DO...LOOP
GO
PULSOUT 13, 600
PULSOUT 12, 600
PULSOUT 13, 750
PULSOUT 12, 650
PULSOUT 13, 800
PULSOUT 12, 650
PULSOUT 13, 900
PULSOUT 12, 600
PULSOUT 13, 900
PULSOUT 12, 700
PULSOUT 13, 900
PULSOUT 12, 750
PULSOUT 13, 900
PULSOUT 12, 900
CASE %1111
PAUSE 100
PULSOUT 13, 900
PULSOUT 12, 600
PAUSE 3
ENDSELECT
LOOP
Check_Qtis:
' surface.
RETURN
