boe-bot control via Xbees
Dear all
We have a pair of Xbees (Xbee wireless pack), and a Boe-bot. We tested the Xbees and they both transmit and receive fine from each others (using the test
scenarios in the parallax tutorial) where one is connected to the PC and the other to the boe-bot.
We tried the program that was used by HackWar and found at: http://forums.parallax.com/showthread.php/129153-Boe-Bot-remote-controlled-with-XBee
and is attached here. The boe-bot is not moving with this program, even though it moves when we use other programs with direct moving commands
without the Xbee.
Is there a detailed steps to ensure that we are doing the right thing?
Many thanks
Waleed
without the Xbee.
Many thanks
Waleed
Also, in the boe-bot book there is no mention of using PIN 14, while in this program there is:
L_MOTOR PIN 13
R_MOTOR PIN 12
servoPin PIN 14
would you kindly explain what PIN 14 does and what should it be connected to in this case?
best regards
