BST not detect propeller
HisNameIsRobertPaulson
I am currently running BST on LinuxMint. I cannot get BST to detect my propeller. After I get a message that says "Propeller not found", I get a choice to use a file path to find the port. I don't know where to go from here. Previously, I used the Propeller Tool on a Windows OS on the same computer and I was able to connect very easily.
- What is the output of the following command: - What Propeller board are you using?
- Does your Propeller have power?
Notice the emphasis (mine) on ttyUSB0: that's where the FTDI chip is. If you don't have that, then it looks like an FTDI issue: most likely the drivers are not installed correctly. Here is the output of "lsusb" on my computer:
There are a couple of other possibilities to check as well, google may find them as it's been a while since I had to fight this issue.
The following boards have worked for me with BST on FCxx through FC17:
PEK on a breadboard w/ propplug
GG USB platform (my main backup now)
Quickstart (on indefinite loan to highschool kid)
propC3
Frank
That might come later, but I don't even see the ttyUSBN port in his ls output, so I don't think that's the issue.
When I run lsusb the following shows up.
Frank mentioned that I should check the USB permissions. How should I do that? Thanks for your responses!
The FTDI chip should not make your mouse move slowly. Maybe try it on a different USB port? In any case, that sounds like a computer problem, not a Propeller issue.
To add your user to dialout, use the following:
