Simple tilt/rotate over sensors exist?
CuriousOne
Hello.I need something very simple, without any mems/gyro/etc. to sense the position of device. The circuit should be triggered when device turned over. Do they exist?
http://www.mouser.com/ProductDetail/Freescale-Semiconductor/MMA8491QR1/?qs=%2fha2pyFadujyDfLlWUGDeECT%2fizTUYUDclHBH9IEEfU%3d
If you want something bigger and mechanical.
http://www.mouser.com/ProductDetail/E-Switch/TM1000/?qs=sGAEpiMZZMtCWdKUURnHj1%252bkvdiUuPvDlfB2tFt2oBI%3d
http://www.parallax.com/Store/Sensors/AccelerationTilt/tabid/172/CategoryID/47/List/0/SortField/0/Level/a/ProductID/722/Default.aspx
How about a homemade one from Forrest M. Mims III?
The one Andrew mentioned, the Memsic sensor from Parallax, is very rugged--no moving parts. It detects the distribution of a bubble of warm gas inside a tiny chamber.
(I do like that one from Forrest Mims!)
Does your product have a mcu?, more info could help.
Freescale's IC does do negative G to detect upside down, but the Tilt Detection Output's are absolute values, eg -1 = 1
I think you should only get a 0 if the item is upside down (135deg to 225deg)
