Low pressure sensor
sidecar-racer
I'm looking for recommendation for a low pressure air sensor; 0-5psi (other ranges considered) it's to be used to measure intake airbox pressure (expected to be positive value at high speed due to ram air effects). Output can be 0-5vdc, i2c or spi (I have different data acquisition options. Existing a/D is 12bits. We're seeing a lean fuel air mixture at high speed at 5000ft so thinking the fuel injection computer isn't smart enough to adjust. Plan to adjust external.
Rick Murray
Rick Murray
-Mike
-Mike
After 5 seconds of research you must be speaking of the Swiss sidecar chassis manufacturer LCR...
