I'm repairing a steam heater that had a thermal fuse and need to reconnect the new one but I can't use solder since the heat would melt it. The original had these crimp connectors but I don't know what they are called or where to get them. Can someone give me a clue? Thanks.
Would wire nuts be an option?
Cheers,
Actually you can solder these.
1. You have to do it very quickly on only 1 lead at a time and as far from the body as possible.
2. It's helpful to use a heat absorbing plier between the body and the place you are soldering.
3. It's helpful to have the body dipped in cold water.
Tin the wire first and leave a gob of solder on it.
Do this as quickly as possible. An extra pair of hands is very helpful.
Duane C. Johnson
http://www.homedepot.com/p/Gardner-Bender-18-10-AWG-Copper-Crimp-Connectors-100-Pack-10-310C/202526312#.UUt30jbn9qM
It is used like this...
Or search google.com for the words...
butt splice connector
...then click on images.
here is a link to there catalog page with ferrules
http://www.mouser.com/Catalog/catalogusd/645/1717.pdf
Hope this helps
Duane J
The trick is to get a counter person to look at what you are trying to do and give you some support. Often they just want you to provide a make, model, and catalog number.
My Mr Coffee thanks me for fixing him.
