elev-8 help !
The problem is that when I tried to arm my elev-8 it didn't arm correctly and still flashing green without any response. I don't know the reason..I've checked the ESCs calibration,the connections and it seems that every thing is ok. bearing in mind that I'm using the dx6i transmitter and I've installed the x configuration....Is there something wrong related to the dx6i settings ? (if so recommend me the right settings) or there's another problem ? please help me as much as u can![:) :)](https://forums.parallax.com/resources/emoji/smile.png)
My ELEV-8 wouldn't arm until I had made these changes. Let us know if you can't find the information.
I have a bunch of ELEV-8 links in post #10 of my index (there's a link to my index in my signature).
No, Spektrums don't need any channel reversing or special configuration to work out of the box, only the gain needs to be set on channel 5 (start with 26%).
The Futaba radios need to be reversed, however.
If you're having trouble arming the ELEV-8, try setting the rudder endpoints at 110% both directions.
Thanks for the correction.
It's the HobbyKing $100 quad that uses Futaba as the defaults.
And now that my memory has been jogged, I realize it was the HobbyKing quad I initially had trouble arming.
@Talaat, Have you used other quadcopters. I know the arming sequence it a bit different with the HoverFly than with the other quadcopter boards I've used. Have you tried reducing the throttle trim? The throttle trim is different than the trim on the other channels. It sets the lowest setting of the throttle instead of the adjusting the center point of the channel. This allows the trim to set the idling state of the aircraft. Many transmitters use a default idle setting that's too high for the HoverFly to arm. Try reducing this idle point on your radio with the throttle trim control.
First question - does the hoverfly arm? If you have the throttle all the way down, then go left than right with the throttle stick, it will beep and flash green, show red (meaning it is calibrating) and then be armed (according precise details seen in the hoverfly manual). So you can easily tell if the hoverfly hears the stick.
If it does arm, but the ESCs are beeping the rotors, you should recalibrate the ESCs. You should also plug one ESC directly into the throttle output from the radio receiver and see if it spins up and dowm on command from the transmitter.
In my case, I calibrated the ESCs with a tester, and it turns out that they didn't respond to the radio because of major differences. Recalibrating with the radio fixed everything.
btw what is happening with me is quite similar to this youtube video :
http://www.youtube.com/watch?v=kHX-iWi64Rs&feature=youtu.be
I'll appreciate any further help
The LED will flash purple like that if the gear switch which puts it into elevation hold is in the wrong position at start up. I recall the "wrong" position seemed like the right one to me.
Don't flip the gear switch while flying unless you really know what you're doing. I had my Maxbotix ultrasound attached when I flipped the switch which then caused my ELEV-8 to do a flip (not in a good way).
and I have some external question..what is the usage of the "glue" that came with the ELEV-8 platform ?
Thanks again..you made my day
That glue is Loctite, and it's for the metal/metal connections. Hopefully you used it when you built the motors.
