Need help with startcog in LMM mode c++ — Parallax Forums
AnubispodAnubispod Posts: 42
edited 2013-03-21 04:55 in Propeller 1
Hi here is my my code what i want to get to run in c++.
So to explain a bit , i have 2 spin files what i have run trough spin2cpp and got 4 new files
See attachments i converted it with --main to make the MPU6050_Demo as main file to run from .
All works well till i get to the point to start the loop from MPU6050_XS in a new cog like i do in spin .
My spin code works well i get in the cog 150 reads of sensor data per sec and stored in the buffer
But i would like to get it to run in gcc to see if it makes speed difference
int32_t MPU6050_XS::Start_loop(void) {    int pin =0;
      int foo= 0;
      int stacksize = sizeof(_thread_state_t)+sizeof(int)*3;
      int *stack = (int*) malloc(stacksize);
      int cog = cogstart(&MPU6050_XS::Loop, (void*) pin, stack, stacksize);
      return 0;
int32_t MPU6050_XS::Loop(int32_t Ptr) {
   int32_t _parm__0000[4];
   _parm__0000[0] = Ptr;
   while (1) {
     _parm__0000[1] = _i2cack;
     if (I2cstarted == -1) {
       I2cstart();
       _parm__0000[1] = ((_parm__0000[1] << 1) | I2cwrite((0xd0 | 0x0), 8));
       _parm__0000[1] = ((_parm__0000[1] << 1) | I2cwrite((Ra_accel_xout_h << 24), 0));
       I2cstart();
       _parm__0000[1] = ((_parm__0000[1] << 1) | I2cwrite((0xd0 | 0x1), 8));
       _parm__0000[2] = 0;
       _parm__0000[3] = 13;
         int32_t _idx__0001;
         _idx__0001 = _parm__0000[3];
         do {
           ((uint8_t *)(int32_t)(&_parm__0000[0]))[_parm__0000[2]] = I2cread(_i2cack);
           (_parm__0000[2]++);
           _idx__0001 = (_idx__0001 + -1);
         } while (_idx__0001 >= 1);
       ((uint8_t *)(int32_t)(&_parm__0000[0]))[_parm__0000[2]] = I2cread(_i2cnak);
       I2cstop();
     } else {
       _parm__0000[1] = _i2cnak;
     Lastackbit = _parm__0000[1];
   return 0;
Error log
   while (1) {
       I2cstart();
       I2cstart();
       _parm__0000[2] = 0;
         int32_t _idx__0001;
         do {
           (_parm__0000[2]++);
       I2cstop();
     } else {
   return 0;
Best regards Oliver. R
  • SRLMSRLM Posts: 5,045
    edited 2013-03-19 17:19
    It might help us if you explain what is not working, and what you have tried.
  • jazzedjazzed Posts: 11,803
    edited 2013-03-19 18:40
    int32_t MPU6050_XS::Loop(int32_t Ptr) // IIRC the function should be static.
    edited 2013-03-19 23:55
    jazzed wrote: »
    I don't think it needs to be static, at least if you are compiling with g++. But it reminds me: I think the function prototype should be something like:
    void name(void * param){
    You should also include a cogstop(cogid()) as the very last line of the function, otherwise your cog will keep running (waiting) and take up resources.
  • ersmithersmith Posts: 6,251
    edited 2013-03-20 05:11
    jazzed wrote: »
    Yes, I think you're right Steve. If it isn't static then there's an implicit first argument (the "this" pointer) which the cogstart function won't set up correctly.
    Eric
  • AnubispodAnubispod Posts: 42
    edited 2013-03-20 08:44
    Ahhh ok i got it , not the way i first intendet but hey as long it runs ...
    I have rewritten the spin code from the loop i wanted to run in the cog to pasm and now the spin2cpp did a better job.
    So for other on the hunt for a starting point for the MPU6050 can look at those files. i included spin_pasm and c++ for c just shoot it trough the spin2cpp and it works.
    Best regards
    Oliver.R
    edited 2013-03-20 09:46
    SRLM wrote: »
    Yes.
    SRLM wrote: »
    That's probably true for functions that terminate. It never occurred to me.
    I've updated propeller-gcc cogstart page entry. https://sites.google.com/site/propellergcc/documentation/libraries/propeller-h-library?pli=1#TOC-cogstart
    Thanks!
    edited 2013-03-20 21:52
    ersmith wrote: »
    Eric
    Well, I checked, and here is what I have:
    1. A "void functionName(void * param)" function, in the global namespace
    2. The propeller-elf-g++ compiler
    3. Called cogstart from the main() function.
    4. It seems to work.
    I don't know if there is an implicit "this" pointer, however. And I haven't tried putting the cogstart'd function in a class, so it may be an issue there. I'd be interested to hear if it is.
    edited 2013-03-20 21:55
    jazzed wrote: »
    Is that sites.google.com page generated from a C/C++ source file, or is it edited directly from the sites.google.com editor? I don't want to add additions to it if it's generated from source.
    ps: I've also added an FAQ related to cogstart.
    edited 2013-03-20 22:43
    SRLM wrote: »
    Most of the propeller.h page was generated using Doxygen and fixed up by hand. The code was created first and pasted into a google text gadget. You can click on the properties to bring up a regular text editor on the site.
    Thanks for working on the FAQ. It has lots of good info in it.
    SRLM wrote: »
    I should have been clearer -- the "static" is necessary only for class members. Global functions will be fine without it (there's no "this" for a global function). But class members will need to be "static", which for a class indicates that it behaves the same for all objects.
