Only works with USB connection to PC in place.
Hello,
I have a problem with a protoboard-based project: the software on it appears to get stuck soon after it starts, re-starting over and over again at one of the first steps - except if the USB connection to the PC is in place, when it runs as intended / expected.
The protoboard is a non-USB version, using a PropPlug.
Any thoughts or suggestions would be gratefully received,
Hugh
Hugh
The symptoms you are describing sound very much like a power issue. The power draw exceeds what the supply can provide and the Prop resets, reboots and gets to a point where it draws more than can be supplied and resets.....forever.
Disconnecting two other devices on the same source allowed it to boot and run properly.
Just off to a neighbour to borrow a battery-charger!
