How to monitor two rotary quadrature encoders at once?
Hi everyone. For my school's senior project I need to monitor two rotary quadrature encoders simultaneously. These two encoders will be used in conjunction to measure bicycle sprockets for quality control. I have one encoder that measures angle which determines if the user has spun the bicycle sprocket while the other encoder measures the size of the teeth relative to a fixed point on a base. My code works fine when I am monitoring one encoder but as soon as I try to start monitoring a second encoder my program stops functioning properly.
I found that when I do the two "quad.start" function calls, the second encoder (in this case the size encoder) is the one that gets monitored and I am unsure why. I tried allocating each call of "quad.start" to a new cog but that didn't work which I'm guessing is due to the fact that the quad function creates a new cog to monitor the encoders anyway. Would anyone know how I could monitor each encoder simultaneously? Thank you for any help!
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
'_xinfreq = 6_250_000
TX_PIN = 0
BAUD = 19_200
MS_001 = CLK_FREQ / 1_000
CLK_FREQ = ((_clkmode-xtal1)>>6)*_xinfreq
LCD_PIN = 27
LCD_BAUD = 19_200
LCD_LINES = 4
LCD_COLS = 20
ENCODER_PIN_SIZE = 5
INDEX_PIN_SIZE = 6
ENCODER_PIN_ANGLE = 1
INDEX_PIX_ANGLE = 2
OBJ
quad : "QuadDecoder"
LCD : "FullDuplexSerial"
f32 : "F32"
f32_orig : "Float32Full"
fs : "FloatString"
VAR
long offset_size ' example variable that will be accumulated to
long offset_angle
long distance
long temp
long distance_tick
long f1
long fA
long angle
long angle_tick
byte cog
long stack[90]
PUB main
LCD.start(TX_PIN, TX_PIN, 00, 19_200) 'Initialize FullDuplexSerial.spin
f32.start
f32_orig.start
offset_size := 0 ' initialize the accumulator
offset_angle := 0
' You can set it to any desired value
LCD.tx($0C)
LCD.tx($11)
quad.start(ENCODER_PIN_ANGLE, @offset_angle) 'start the angle encoder
quad.start(ENCODER_PIN_SIZE, @offset_size) ' start the size encoder
LCD.str(string("Size ="))
LCD.tx($0D)
LCD.str(string("Angle ="))
LCD.tx($0D)
distance_tick := 0.000983
distance := 0.0
angle_tick := 0.144
angle := 0.0
repeat
distance := f32_orig.FMul(f32_orig.FFloat(offset_size), distance_tick)
angle := f32_orig.FMul(f32_orig.FFloat(offset_angle), angle_tick)
LCD.tx($87)
LCD.str(fs.FloatToFormat(distance,13,6))
LCD.tx($9D)
LCD.str(fs.FloatToFormat(angle,10,4))
waitcnt(clkfreq/100 + cnt)
The object needs to be named differently. Theres a few ways to do this.
You can do like I did and rename them differently, this means you take up more codespace for the same code.
Then when you go to use either encoder, you address them with their names properly (quad1.start and quad2.start)
Or to save codespace you can do this.
In this situation you must use the object like this:
quad[0].start
quad[1].start
Many quadrature encoder obex objects allow more than one encoder to be connected. In that case, the pins for the encoders must be sequentially connected to the prop.
The data is found by addressing the dataspace properly, and that reminds me, make sure your variables that the encoder object uses are duplicated also, two encoder objects will need two sets of variables.
