Servo weight limit
Android
Hi guys i want to make a robotic arm out of wood using two servos for 2 degrees of freedom. I would like to know how much weight the servos can hold up horizontally. Anything helps!
-Android
-Android
I would not recommend a continuous servo for a robotics arm.
You'll have to look at the servo specs and find a servo that meets your arm requirements. Asking the question Do you have any ideas on motors that are good for a robotic arm. has no context with out specific details.
What kind of ice cream should I buy?
The Parallax CR servos says it has 38oz*in torque. The amount of weight it can hold horizontally will depend on how long the arm is. A one inch arm can hold 38 ounces. A 12" arm can hold 38/12 or 3.17 oz.
The 38 oz*in figure assume a 6V supply. The torque will be less at 5V. You should also not drive the servo at its max torque for long so you should make sure you have a good margin of more torque than you need.
I have links to some of the servos I like in post #10 of my index (near the top of the post).
Vanilla, duh!
-Android
IMO, you're better off doing it the wrong way than not trying at all.
I have lots of failed robots that were successful experiments.
Here are two of my favorites.
Hexapod with ridiculously long legs. Destined to fail, but I learned a lot.
Expanded rims on the Rover 5. I tried the exact opposite of what I would eventually work. It was only because I posted my failure to the forum that I learned the right way to do it. BTW, After erco's help, I can't get a tread to come off even when I try.
So go ahead and make mistakes. I hope you share the mistakes you make here. I also hope you share your inevitable successes.
Rich suggested preloading to "balance" the load, which certainly helps. Counterspringing is usually better than counterweighting if done properly.
Per Duane, try something and learn. And share your findings here!
