SumoBot Tilt Control
From the title... Has anyone used these circuits/programs: http://learn.parallax.com/project/xbee-sumobot-tilt-controller
I've been fiddling with this most of the day and can't get them to work. Well, I can get the "Test Accelerometer" program to work, but when I load the "XBee Tilt Controller CH B.bs2" program, Debug just shows "Configuraing XBee" for a while then just stops. There seems to be continuous communication between the peecee and the H/W board.
Then... when I upload the "XBee Tilt Controlled SumoBot CH. B.bs2" program to the BoeBot, I get the same result.
I've wired and rewired half a dozen times and I'm darned sure the wiring is correct. Any thoughts?
Amanda
Problem solved! While wiring and rewiring the Xbees, I relied on my memory for the pin locations. Wrong! After pulling off the 5V adapter, I noticed I'd missed the Din/Dout connections by one pin. C**p!!!!
So... everything works just fine. More tinkering ahead.
Amanda
I'm still going to try it someday. It looked almost too easy to be true.
After finding my mistake, I decided it =was= pretty darn easy. Haven't found the range with the Xbees... I'll report back a bit later. Going out to play with him for a while.
Amanda
I'll look at antenna positions and module locations to see if I can tweak a bit more out of the setup.
Amanda
