cmucam4 chip lost on vom
Hello I am trying to getting started with my new cmucam4, and I have the problem with it ,the message propeller chip lost on com appears.
At the beggining when I first conencted the interface to the cmucam and started the parallax serial terminal the system recognized the version of the cmucam after i tried to update to the version 1.2 this problem of chip lost initiated.
It seems like the firmware is absent in the cmucam. The parallax writes card not detected .
Tried to connect an external supply but the problem persists.
Anyone had such a trouble
thank you
thank you
This is Kwabena - If you haven't solved the problem by now, you might want to just return that CMUcam4 for a refund and get another. Given that it worked once, you also might want to try a different programmer if you haven't already tried.
Anyway what programmer would you suggest?
There's probably a distributor in your area you can buy one from. They are essentially the same thing as the FTDI cable.
BTW, did you set the propeller tool to toggle both the RTS and DTR lines in the options menu?
I still have no idea what your problem is, I don't think its the prop chip however as it won't even be found or begin to program if its broken... something must be wrong from the programmer end to your computer.
The prop plug that you send me the link slips into 4 pin, FTDI that I have is 6 pin do you think it can be a problem?
I am using as software the propeller tool, if I try using something else, if exists something else?
Um... for other options... there's BST http://www.fnarfbargle.com/bst.html. But, it doesn't support the RTS pin so you're not going to be able to use SparkFun's stuff with that.
Then there's the Prop GCC. They have a loader: https://code.google.com/p/propgcc/ - However, its command line. Maybe the SimpleIDE can load SPIN binaries: https://sites.google.com/site/propellergcc/supplements/propgcc-compiler
Yeah.... The prop tool shouldn't have a problem... I doubt the other tools will get it working.
Do you have a photo of your current setup with the FDTI cable? That would help a lot.
A picture of how you have it connected (wired).
Here it is
I think when I updated the version of the firmware to v.1.02 something went wrong and there is no any firmware on the cmu. Do you think there is a way to upload the firmware with the help of SimpleIDE? never used Simple IDE
Here's the info for the prop loader: https://code.google.com/p/propgcc/wiki/PropGccLoader
It looks like your going to want to do...
"propeller-load -e !CMUcam4_Firmware.bin"
It should automatically find any propeller chip attached and load it. Just find where the propLoader is and launch it. Its probably in the /bin directory where propgcc installed.
