LED. Question.
Hi there can any one help with this query. I am of limited electrical expertise but I would like to fit an led into my charging
system of my portable electric screw driver, I apologise for what I suspect is a very basic procedure.
1. Charging system plug : Input 240 V ac.
Output 3.3 V. 200 ma.
2. Voltage measured at the screwdriver charging points : 3.34 V ac. with no polarity ?
3. Screw Driver data plate : Black & Decker Type 1 : 2.4 V ac.
1300 rpm.
The insertion of a suitable 'led' is so that I can see at a glance if the charger is working as the charging point is in a
very darkened area. I know move the charger but I just want to complete this very small project.
regards,
mike............
1300 rpm.
regards,
mike............
The peak voltage would be:
3.34VAC * 1.414 = 4.72V peak
Most, if not all, LEDs have reverse breakdown voltages higher than this, so no harm no foul.
Start with a ballast resistor of about 100Ω or so for about 10mA average LED current.
Duane J
If you don't the LED to stay on from the power of the battery, you may need to cut a trace and put a diode there.
Even if you have a low voltage that is close to the LED forward voltage, you still should put a limiting resistor, 120-200ohm is OK.
2) You need a current limiting resistor because, above the threshold (Vf - Forward Voltage) of the diode, the diode will conduct as much current as can be supplied (until it burns out). See this chart for common Vf values. A bright red LED will typically have a Vf of around 1.7V. If you connect that to a 2.4V power supply, it will promptly burn out. If you put a silicon diode in series, the total Vf will be 1.7V + 0.7V = 2.4V. If you connect that to 3.34VAC, the LED will burn out (first). The silicon diode will probably last longer because of how it's constructed. You would usually pick a resistor value that would limit the current to about 10mA.
Resistor value = Voltage / Current = (Power Supply Voltage - LED Vf - Silicon Diode Vf) / 0.01A [ You could use a lower current value with corresponding less light produced ]
With a 3.34VAC (peak voltage) supply, that would be (3.34V - 1.7V - 0.7V) / 0.01A = 0.96V / 0.01A = 96 Ohms (use 100 Ohms as nearest standard value)
You could actually use a higher value for less light, maybe 150 or 200 Ohms.
Duane's calculation for peak voltage assumes that the 3.34VAC value is RMS voltage (root mean square) which is more commonly used than peak voltage for AC voltage ratings.
silly questions only silly answers.
thanks much appreciated,
